Hi
I built this circuit on a test board
http://www.redcircuits.com/Page68.htm
the sensing leads are simply two thin copper wires
i connect these two leads together, this equivalent to a very low resistive solution.
when operate the circuit, the red led (D3) is on and the other green and yellow are OFF
when trying to adjust the variable resistor R4, it has no effect at all
i check the connections many times, they are OK.
I understand the three comparators operation
and know that the two red leds D1 & D2 are a voltage references as the writer said
also i know that the first op amp (IC1A) is function like this:
and this:
I use a 10.5V power supply
I measure pin1 voltage = 9.1V where pin5 = 4.3v
i try to make pin1 voltage lower than pin5 but can't
please help me in fixing the broblem
thanks
and this:
thanks
