Samsung 43" rear projection.
Dani
Dead, won't come on, led is on at standby, & just flashes at turn with
remote, indicating SMPS is ok, & getting signal to turn on. Unplug
connector CNZ04 from convergence, pop in speakers, tries to start, but
shuts right down. Sanyo STK 394-250 IC's seem ok, & all fusible
resistors check fine. Can't get at the board to do measurements,
without removing it totally. No leaks.
Anything common on this model? Dani.
Dani
Model # HC-R4351WX/XZC. Chassis # P60B
Jamie
Sure, Check the HOT Section and fly back maybe! :)
Meat Plow
Convergence IC, common problem.
Art
Check the set throughly for possible leaks from the crt coolant chambers.
