Samsung 48" rear projection TV Model No. SP48T5HP
We are currently experiencing problems with our Samsung TV (3yr old) in
that it will switch on, making its start up tune and shows a text
pattern type screen but within a couple of seconds it turns off again.
Do you have any ideas what this could be as other sites have indicated
it to be a timer setting problem which sounds odd because i cant get
into the menu to check the setting as it keeps turning off.
Cheers,
Scott
James Sweet
Cheers,
Scott
It's probably the system controller detecting a fault and shutting down
the set to prevent further damage. You should get it looked at by a tech
to diagnose the problem.
