samsung crt slim tv
geylord tacahl
Oct 19, 2015
vertical, 4inches lang ang picture nya, ngpalit n aq ng vertical-out,ganun pa din. pls mga master, help me..
translation
vertical picture, is only 4 inches high. has changed the vertical output but nothing changed
help me
73's de Edd
Aug 21, 2015
3,730
Actually . . . . .it's . . . . Help,Help me Rhonda . . .
"My widdle tee-wee only has 4 inches of picture, I've changed the vertical output, but its still being the same."
With an IP identifier located somewhere from the back alleyways of Baguio City.
Ismelda Marcos say:
Sr Geylord Tacahl,
Ibigay sa amin ang modelo o chassis number ng Samsung unit, muling ihinang koneksyon ALL .. .ALL . . .ALL . . . paligid ng vertical circuit.
Dahil ang banggitin ng mga ito sa pagkakaroon ng isang vertical output, hindi ba ito isang uri CRT ng televisioon sa halip ng isang flat panel TV?
73's de Edd
73's de Edd
Aug 21, 2015
3,730
Sir Martaine . . . .
OK . . . .then . . . .more conservatively . . . .sometimes a little tap-a, tap-a,tap-a on the chassis PCB in that area, using a small plastic
screwdriver handle, can reveal an intermittent solder/to /component connection.
Ergo . . . therein not necessitating a more involved banging.
73's de Edd
Martaine2005
May 12, 2015
5,318
Hi Dan,
I do believe it's Philipine. That's why I called for Daves help:)
I THINK I said " Now that's impressive" to Edd. I HOPE I did anyway!!:eek:
Martin
GPG
Sep 18, 2015
452
One end of the vertical deflection coil will be connected to the IC, the other to an electrolytic capacitor. Check the capacitor.
