Mike said:
Only by people that don't understand that it's a waste of time, as any reverse-engineer worth their
salt will be able to figure out what the chip is in typically a few minutes.
If we're talking about those single IC FM radios that have two buttons
to tune it, a "scan" and a "reset" button, it was easy when I looked.
I bought one out of curiosity, and when I saw no ceramic filter inside,
it became clear that it was likely like the old tda7000 IC that converted
down to the tens of KHz range for active filtering to work, But the pin
count was wrong. I checked the Signetics website, and they pointed
to variants of the original IC, and one of them matched the pin count
and then I traced the circuit based on the assumption it was that
IC, and there it was. I've posted about it, I can't recall the IC
but it was something like "7088". In my case, the number hadn't been
sanded off, but it was certainly difficult to read (maybe had bee
only partially sanded, though it didn't look like it). Once I knew
the IC, and a I looked at it again with a good flashlight, the correct
number was legible.
Of course, it was easy since there was only one IC, and there are a limited
number of those that could do the job. The more ICs, the more work
tracing the circuit requires.
SOmeone suggested they were a source of parts. Unless you needed the
specific IC, there isn't much in them. I could get more parts out
of that older CD player I saw waiting for the garbage the other day
(I guess my parts collection is fairly full, because I didn't even
pull the transformer, but then I was carrying a boombox that I'd
picked up further down the street), or that TV set circuit board
I did bring home a few weeks ago (it was conveniently detached from
the tv set, so I just had to pick up the board).
Michael
