Scanner radio works with wrong power supply?
Gulfstreme
My radio scanner didn't come with an ac adapter so I'm using one that
I had lying around (and that fits the plug) and it seems to be working
fine even though the voltages and amperages are different (see below).
scanner input - 9v dc 300mA
wall-wart output - 6.5v dc 2.5A
Could someone explain how/why this works? It seems to me that 2.5
amps would be too much since the input calls for 300mA. Is the 2.5A
wall wart putting out *up to* 2.5A depending on the draw from whatever
is hooked up to it? Is the 6.5 volts just *enough* to power up and
use the scanner? I've just been wondering about this for a while
now.. thanks for your replies.
BTW: the scanner is a Radio Shack Pro-95
AC/DCdude17
X-No-Archive: Yes
I bet the 2.5A 6.5V DC wall-wart puts out about 9V when you're only
drawing 300mA. It puts out 6.5V when it is under 2.5A of load.
