Schematic capture software recommendation
AnalogKid
Jun 10, 2015
3,058
For the next few weeks I will be without my beloved ViewDRAW. I'm looking for experience-based recommendations for a schematic drafting package. Requirements:
1. Local operation. No cloud-based libraries, website GUI, etc. Download and install; Cut internet cable; Use.
2. Prepackaged libraries always are a plus, but I'd like to be able to create my own as well.
3. No netlist export required at this time. This is for quickie-drafting an idea, such as a timer circuit to post on EP.
4. Direct PDF and JPG or GIF output a plus.
5. Free is nice.
Thanks.
ak
OBW0549
Jul 5, 2016
157
I recommend Eagle. The Express freeware version for non-commercial use would stack up against your list as follows:
1. Check.
2. Check, including creating your own library parts.
3. Check. Netlist export is included.
4. Check. Also available is image export to the clipboard.
5. Check.
The only difference between the freeware version and the commercial versions is the maximum # of schematic sheets (2), the maximum number of routing layers in the board editor (2) and the maximum PCB size (100mm x 80mm). Otherwise, the freeware version is fully functional.
Downside is a significant learning curve-- but in my opinion, it's worth the effort.
Kicad is Great. It does ask this things. Once you've learned how to master it and become competent, there will be a short time left before the heat death of the universe.
My experience was that kicad could do everything I needed and more, but it required a dedication I thought I was prepared for, but in reality I wasn't.
Are you familiar with DaveCAD? I take a stylus for this wherever I go.
Minder
Apr 24, 2015
3,561
Kicad does it for me
If no board layout and Gerber needed then for a simple schematic only there is Diagram Design and TinyCad.
M.
