jdhar
- Jan 1, 1970
- 0
I am having a seriously difficult time resolving an issue with a
custom IC and the SDIO device interface on it.
The setup:
Device IC (with SDIO interface) <---> 8-pin male 100 mil header on PCB
<----> Short cable <---> SDIO Finger PCB with 8-pin male 100 mil
header <----> Host system with SDIO slot
So the device IC resides on a PCB with an 8-pin header. The SDIO
finger PCB is a small PCB that is in the shape of a SDIO card, and it
has a matching 8-pin header. This plugs into the SDIO host.
The problem:
Spurious interrupts are generated/detected in the system, and CRC
errors occur from time to time.
Details:
The first problem is narrowing down whether this is a Signal-
integrity (SI) issue, or a RTL/IP issue. Right now, the symptoms are
pointing to an SI issue, however, I can't seem to accept that an SDIO
interface running at 10 MHz would be prone to SI. I know that SI is
more related to edge rates instead of frequency, but still at 10 MHz,
the system should be relatively forgiving. Some interesting notes:
- Using a regular IDC ribbon cable yields the worst results; ie, more
frequent CRC errors and sometimes the setup dies immediately
- Using Coax cable on all signals (with grounds tied together on both
ends) definitely improves things
- Soldering the Edge-finger board directly to the Device Board also
improves things, but still not completely resolved
- Increasing the length of the Clock trace to 70+" with the rest of
the signals at ~3" improves the same way coax does. This is what
yields me to believe it may not be purely an SI issue.
- Adding series resistance or small shunt capacitance doesn't yield
any noticeable results
- Clipping a regular passive probe onto the clock line improves things
I have probed all of the lines with active probes (since passive
probes change the results), and there is no noticeable quality issues.
I am probing at the header on the Device side, which is about half way
between the 'chain'.
Any suggestions on where to look here? I'm at wits end!
The setup:
The problem:
Details:
