sdram --> ddr design possible?
Dan Kuechle
I currently have a (single data rate) sdram design that runs at 40mhz.
Sdram is used primarily for low cost, not for speed. We want to switch over
to DDR (double data rate) because prices are getting cheaper than sdr sdram
and densities are getting higher. If anything, we would want to go to a
wider bus at 20mhz, rather than run at higher frequencies. From what I can
see about DDR, this would not be possible as there is a minimum frequency of
about 80mhz according to the spec sheets. Could someone in the "know"
verify this: that ddr sdram needs its clock to be within a fairly narrow
range... greater than 80mhz and less than its max clk speed. Any way around
this?
Dan
Allan Herriman
this?
Clock phasing in DDR is rather important, so they use a DLL or PLL
inside the SDRAM chip. This leads to the lower frequency limit.
Various chips may have test modes in which the DLL or PLL is disabled,
but I'm not sure if this will work the same in chips from different
manufacturers, and I don't think the I/O timing will be guaranteed in
this mode.
80MHz (not mHz!) isn't terribly fast. Why can't you run your
controller at 80MHz? This should be cheaper and easier than using a
bus that's four times as wide at 20MHz.
My latest DDR SDRAM interface in an FPGA clocks at 160MHz (data rates
of 320Mbps per pin) and uses a 64 bit bus.
80MHz sounds ... pretty close to DC to me.
Regards,
Allan.
Allan Herriman
Oops. Can't count. That should be a 32 bit bus connecting to two 16
bit wide chips.
Regards,
Allan.
Stefan Heinzmann
this?
You may want to read the JEDEC standard document JESD79C
(www.jedec.org). It defines the common ground you can expect from DDR chips.
Similar threads
F
Replies
1K
fpgabuilder
F
Y
Replies
4
3K
Michael A. Terrell
Replies
1K
Jeff Walther
