Security Light
BeeJ
Need parts suggestions or a purchasable finished unit for a security
light.
1) plugs into 110VAC 60 Hz
2) Li ion battery preferred but 12V gel OK.
3) charge circuit for charge and maintenance
4) One or two LED lamps. Can get 12V 6W bi-pin lamps with good
brightness for $19 each. Purchased one and like it.
5) night/dark enabled
6) motion sense to turn on.
I have looked a local HW stores and on line but found no complete
solution. Electronic part stores have very expensive charge modules
($35 for a 12v 300 MA / float wall wart unit)
I can get a solar charged Li battery with LEDs unit $19. Could add an
AC adapter/charger and a walk sensor. Just some thoughts.
Suggestions please.
Jamie
BeeJ said:
Need parts suggestions or a purchasable finished unit for a security light.
Suggestions please.
http://www.harborfreight.com/60-led-solar-security-light-69643.html
Jamie
Martin Riddle
light.
Suggestions please.
Get a Emergency light box and add the motion and light sensors.
most use Lead acid batteries.
Cheers
Artemus
Cheers
If the OP can't add a wallwart charger to the HF light proposed by
Jamie how is he going to manage this?
Art
BeeJ
Artemus explained on 3/17/2013 :
Art
Had all the HF LED lights in my hands in store.
most are NiCd - no thinks
batteries are all behind a dozen or so screws so I could not
determine ease of modification. Could no determine number of cells.
the manuals on line are the same as in the box and are of NO use.
BeeJ
BeeJ laid this down on his screen :
4) One or two LED lamps. Can get 12V 6W bi-pin lamps with good brightness
I have looked a local HW stores and on line but found no complete solution.
Electronic part stores have very expensive charge modules ($35 for a 12v 300
I can get a solar charged Li battery with LEDs unit $19. Could add an AC
Suggestions please.
I would rather work with a 12V system.
