See-through wire mesh to ESD/RFI protect LCD?
Joerg
After trying Google, McMaster, and lots of others: Is there a
see-through (thin) mesh that can be fastened to the back of a steel
panel using conductive epoxy around the perimeter? Preferably something
that can't rust.
It is to protect a LCD from getting hit by strong fields or really big
ESD zaps. Currently there is only some kind of poly film 1/10th" away
from the LCD (doesn't touch). It's ok if the translucent properties
aren't top notch since the LCD is back-lit pretty well.
Robert Obermayer
Hi Joerg,
while i dont know about wire mesh, i do know something that might also
help and would be worth a try: RS 264-9382 is supposed to be fairly
conductive and more or less transparent.
Its very expensive though, probably okay for low volume things but
certainly not something you might want to use on cheap, high volume
devices...
Joerg
Robert said:
Hi Joerg,
devices...
Thanks, Robert. Had cancelled right away because it should have gone
into sci.electronics.design instead but I guess cancels don't work well
anymore.
The price would be ok, we have to save an existing (large) base of
units. But this film probably can't be glued on easily from the back.
Robert Obermayer
anymore.
Id glue it on with a strip of doule-sided film and then use aluminium or
copper tape with conductive glue to get a electrical contact between the
conductive side of the film and the front panel.
Ive seen similar construction on a display unit (probably from a old
cash machine) i found at some trash yard.
Joerg
That's a good idea. As long as this stuff survives "baking" in hot
climates without falling off and into the circuit ... bzzzt. These units
will sit in the hot sun all day long.
Joerg
Jamie said:
Lead glass window?
That would be hard to install in a reliable fashion. And the guys in
Brussels would be pelting us ;-)
Jamie
that can't rust.
Lead glass window?
Anthony Fremont
something that can't rust.
Something like this?
http://www.twpinc.com/twpinc/control/category/~category_id=TWPCAT_1?gclid=CJvN6p7mlJECFQMQlwodnAGrPg
Jamie
Spehro Pefhany
that can't rust.
Joerg- google on "ITO film". Not a mesh.
Best regards,
Spehro Pefhany
Joerg
It'll might a challenge to mount that onto the back of a steel panel
though. Probably comes with an adhesive but that can stick to the
existing polycarbonate that's already there if someone presses it hard
enough.
Anthony's hint produced this:
http://www.twpinc.com/twpinc/control/product/~category_id=TWPCAT_11/~product_id=050X050T0012W53T
Now I just have to get a sample, find some really good conductive epoxy
that will hold up in tropical climates and we'd be home.
Anthony Fremont
epoxy that will hold up in tropical climates and we'd be home.
My favorite 2-part conductive "glue" is made from tin and lead. Can't
recall the name though. ;-)
Lostgallifreyan
http://www.ecn.nl/docs/library/report/2002/rx02052.pdf
Might help, anyway, I was looking for something different when I found that.
It describes silver loaded epoxy for connecting fragile solar cells.
And if anyone knows a good thermally conductive epoxy to bond a thin (0.5mm)
layer of copper onto a thick (>3mm) aluminium base with very strong bonding
and very good thermal conductivity, please post. I don't mind if it's
electrically conductive or not, it must be low viscosity though, to form a
very thin strong bond with no voids.
Lostgallifreyan
I'd use it if it would glue aluminium. Tried HTS2000 but without a flux,
forget it, and the maker doesn't just not specify a flux, they specifically
specify NO flux...
Joerg
Can't solder or weld here, it's a 3mm steel panel with plastic on the
other side. Which also kind of precludes heat-cure stuff such as Loctite
3880.
Joerg
They say "New lamination materials are available that can be processed
at even lower temperatures like 80°C." That's still a bit highish but I
wish they had mentioned some manufacturers.
Wish I could help but that's really outside my expertise. Maybe contact
a Loctite engineer about it?
Lostgallifreyan
3880.
What margin for temperature? Even the tropics should leave you enough to try
one of various indium based solders.
Lostgallifreyan
Ok, maybe indium solder then, like I mentioned in another post. 73.8°C for
65% In 35% Bi.
O. K. A. Metalloids in NY make it, I think. It should work well with a resin
flux.
Maybe but I want to see what general advice I might get before turning to a
specific manufacturer.
