Eng. Tech.
- Jan 1, 1970
- 0
Greetings all,
Perhaps I'm just getting old, and losing my powers of concentration (if I ever had them), but the analysis of the circuit shown below eludes me. This is a work-related test fixture where I must set a test current and test voltage external to the device under test, so most of the circuit elements are fixed values. My attempt at an ascii schematic (mono-spaced font needed for viewing) is pasted below, along with it's notes. TIA,
Sincerely,
An engineering tech who should be better at this by now
Rs
+14.5V<---/\/\/--+----+ +5V
90 | | ^
| /Ra _ schottky
\ +--/\/\/---+---o o--/\/\/---+---0 Vtest out
Rc / | 180 S1 47 |
| /Rb /500
| | +---0 Vtest/2
/500
The resistor values shown are constraints I can't change.
Vtest must be 4.0V with S1 closed, so current through the 1K divider will be 4mA.
Total current through 90 ohm resistor Rs must be 10 mA with S1 open.
Ra + Rb = 10K, but this isn't a requirement.
The schottky shouldn't conduct when S1 is open.
I only have control over Ra, Rb, and Rc. All else is pre-existing equipment.
If Ra and Rb can set the 10 mA current, then Rc is not required.
S1 could be closed for both test cases, but when open the schottky shouldnt conduct
(not sure the +5V supply can "sink" current from 7 idle channels).
This shows the first of 8 test cases. Next will be 3.5V and 15 mA, 3.0V and 20 mA, etc.
Sincerely,
Rs
90 | | ^
| /Ra _ schottky
Rc / | 180 S1 47 |
| /Rb /500
| | +---0 Vtest/2
/500
