Seeking help on decreasing voltage & current for personal project
Steve
All,
Please forgive me if this is in the wrong group.
I'm trying to make an external battery source for my Digital Camera
using mostly stuff I have laying around or can pickup locally here in
Missouri.
I own a Kodak ZD710 Digital Camera - I'm wanting to use a portable
external battery I bought from CompUSA when they closed the store in
my area several years ago.
The battery is "Initial RB-270 9V/5400 mAh" (http://www.initialdvd.com/
accessories.asp)
I used the battery a couple of days while travelling other than that
it's been in a drawer.
Looks like my Camera requires 3V / 2.5 Amps
I found this by looking up a compatible AC adapter on Ebay
http://cgi.ebay.com/ws/eBayISAPI.dl...ksid=p3907.m29&_trkparms=algo=LVI&its=I&otn=2
Question is there some component I can send the output of the battery
through to drop the voltage and current to where I need them. 3V / 2.5
Amps
My goal is to have a lightweight portable external battery that last
longer than the AA batteries.
Steve
Steve
Thanks Paul,
I've spent the last couple of hours making a pack using 2 D cells.
How long should a full charged pack last?
Can you explain - why 2 D cells last longer than 2 AA cells - If both
produce 1.5 volts.
I'm not following
Thanks Again
Steve
Steve
Thanks Paul,
produce 1.5 volts.
I'm not following
Thanks Again
Steve
- Show quoted text -
Update:
I used 2 D cell batterys - I tested the output @ 3.24 volts
When I connect to camera nothing happens
Any suggestions
ehsjr
Steve said:
Thanks Paul,
produce 1.5 volts.
Think of them as similar to gas tanks for your car.
A larger tank contains more gas. With more gas, the
car can driver farther.
Batteries contain chemicals that react to produce the
voltage. If the AA and the D batteries are the same type,
then they contain the same chemicals. The D is bigger, so
it contains more of them, and therefore lasts longer.
Ed
JosephKK
Thanks Paul,
produce 1.5 volts.
I'm not following
Thanks Again
Steve
Really quite simple, the D size cell carries 4 to 5 times the energy
of an AA cell, thus should last 4 to 5 times as long.
Jasen Betts
Thanks Paul,
produce 1.5 volts.
I'm not following
same reson a 205l barrel of fuel lasts longer than a 20l jerry can
