Self-made transistor RAM
AlekseiX86
Apr 18, 2013
8
I a'm newbie in circuit , but i have an idea to create simplest computer using only discrete diods and transistors.
I want to ask about reliability of such computer , especialy about reliability of simplest RAM memory made from discrete elements. I mean would no it be often fail some parts of computer?
And how many transistors will be include such memory , for examle 100 Bytes.
Thanks for helping.
NuLED
Jan 7, 2012
294
I am a newbie too but I think if you are wondering if this type of device will fail less easily than a "regular" computer, I think it might be about the same. The semiconductors inside diodes and transistors are just as sensitive to damage.
A more robust (tougher) circuit might be one that only uses electromagnetic RELAYS (like before the days of semiconductors) but you will need many hundreds of of them if you want to construct all the logic gates to create a basic calculator, using a memory space.
I could be wrong but this is my understanding so far of electronics.
Twodio
May 17, 2013
35
I already saw some creations and computers using simple BC548 transistor some resistors and leds to build a basic 2-bit or 4-bit computer, but even i was give up because i dont had some materials including resistors.
A simple 4-bit processor use more than 15 transistor, because they are used to build AND, OR, NOT, XOR, etc gates.
here go some of pages that i've found and saved as study material:
http://www.metafysica.nl/circuit.html
http://www.waitingforfriday.com/index.php/4-Bit_Computer
Good lucky for you ...
duke37
Jan 9, 2011
5,364
Chips are very reliable, it is the connections between them which are the problem.
100 bytes = 800 bits
I think you will need two transistors for each bit = 1600 transistors plus maybe the same number of resistors.
Relays are not very reliable as was found when decrypting the Enigma code. This led to the development of the computer based on valves (tubes).
Raven Luni
Oct 15, 2011
798
There was a great article I came across ages ago (cant remember where) that talked about this stuff from the ground up from the bistable multivibrator (2 transistors) to latches, flipflops etc. with some good points about clocking and edge triggered inputs
gorgon
Jun 6, 2011
603
Just from the top of my memory, a static RAM bit cell needs about 5 or 6 transistors, that's 4000 - 4800 transistors for 100byte. In addition to that you'll need several 10s of transistor to decode the address and select each byte. In addition to the transistors you'll need a load of resistors, and maybe some diodes.
Actually you can build a static RAM cell with only 2 transistors. It is simply a discrete SR flip flop.
NuLED
Jan 7, 2012
294
AlekseiX86
Apr 18, 2013
8
Intresting : is it possible to made computer which will be able to render 3D graphic and high optimize for this. Ofcourse using only chips. In video ram chip will be colors of all pixels , and then just need to made controller which will be convert video signal in RCA (like in SEGA consoles).
For example 640x480 = 307 200 pixels.
Or in another case just 2D graphic.
But i think it will be necessary high speed ram chips and the same chip logical elements.
And it is not hard to write transaltor from some selfmade high language to this computer's binary code.
No OS , just render for render code processing.
How do you think about this?
Thanks for reading.
Yes, Intel, NVIDIA and AMD, do this quite well.
