Self-Resonant Frequency and Resonant Frequency
W
w2aew
I searched both terms on Wiki
http://en.wikipedia.org/wiki/Self-Resonant_Frequency
and
http://en.wikipedia.org/wiki/Resonant_frequency
I still don't understand what is the difference between them. Let says,
what is the meaning of Self-Resonant Frequency in an Inductor compare
to Resonant Frequency of a Transducer?
Thanks.
Resonance (in electrical parlance) refers to the frequency where the
capacitive reactance is equal to the inductive reactance. At this
point, the phases cancel and you get a sharp change in the overall
impedance. For example, a parallel LC circuit (capacitor in parallel
with an inductor) will be in resonance at a frequency where 2*pi*f*L =
1/(2*pi*f*C). At this frequency, the impedance of this parallel LC
circuit will be extremely high due to the phase combination.
Normally, the term "self-resonant" frequency refers to the resonant
frequency of a component due to the parasitic characteristics of the
component. For example, the physical construction of a capacitor will
determine the parasitic inductance of the leads/connections to the cap.
The frequency where the capacitive reactance of the cap and the
inductive reactance of the lead's parasitic inductance, is the
self-resonant frequency. It is a property of the physical
characteristics of the device - and to some extent, defines where the
cap no longer behaves like a cap, but begins to behave like an
inductor.
When designing resonant circuits, you pick the capacitance and
inductance. Ideally, you will operate at frequencies that are far away
from the self-resonant frequency of the individual components. Of
course, there are special circumstances where you might do a design
that involves utilizing components near their self-resonant frequency,
but it isn't that common.
default
and
Thanks.
An inductor has a "self resonant" frequency bacause the turns of wire
have small "parasitic" capacitors to each other and its surroundings.
Two wires laying next to each other form a capacitor . . . the self
resonance in a tesla coil produces higher voltages than the simple
turns ratio of the transformer might account for. Electrical
resonance.
Self resonance in a transducer may be electrical and mechanical. For
instance, a piezo transducer when struck will produce voltage, but it
will also vibrate for a period (like striking a steel bar) after it is
struck. The mechanical vibration also produces voltage till it dies
out.
If you drive a transducer at its resonant frequency it is much more
efficient at producing output. The analogy is to push a swing just as
it is about to start its return motion.
Jim said:
[email protected] wrote in @m73g2000cwd.googlegroups.com:
It would help if you tell us what kind of transducer you're talking about.
I would like to clarify the components I talked about.
For Inductor:
http://www.mouser.com/catalog/627/782.pdf
For Transducer:
http://web.pui.com/AudioCommerce/images/catalog/audiopdfs/AI-4228-P-SP250.pdf
They use "Self-Resonant Frequency" for Inductor and "Resonant
Frequency" for Transducer. I wonder if that is the same term. Is the
word "Self" implied something?
Thanks...
Michael A. Terrell
For Inductor:
For Transducer:
Thanks...
No, they are not the same. Self resonant frequency happens because
no inductor is pure inductance. It also has resistance and capacitance.
As the frequency goes up, you reach a point where the inductor no longer
has the characteristics you need. When you choose an inductor, you want
to make sure that the SRF is above the frequency you need. I prefer at
least a 50% margin.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
least a 50% margin.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Thanks. I understand Self-Resonant Frequency now. However, I may miss
this but let me make sure I got everything correctly. So Resonant
Frequency of a Transducer is to get to the max output (the closer, the
better), while Self-Resonant Frequency of an Inductor is to "stay away"
(the higher, the better). Am I wrong?
Michael A. Terrell
No, that's it in it's simplest form.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
