Semi Automatic water overflow controller
Prashant Zingade
Sep 7, 2016
9
Hi All,
I created latch circuit to start water pump manually and stop Automatic, in that I'm facing issue when i touch probe of wire by hand circuit start Automatic. Im using 12v 1Amp SMPS power supply.
How to reduce sensitive ?
Please help.
Circuit diagram attached.
14,317
SW 1 is for manual start,
SW 2 is for automatic stop, right?
Try adding a capacitor from tha base of Q1 to ground (0 V) to reduce sensitivity to noise
Prashant Zingade
Sep 7, 2016
9
Also I notice that when I use 9v 500ma power supply it work good. But when I use 12v / 1amp supply its become more sensitive.
What will be the value for capacitor to Q1 base and ground.?
Alec_t
Jul 7, 2015
3,821
I would suggest adding a pull-down resistor of ~100k between Q1 base and ground to ensure the base is never 'floating' at an ill-defined voltage. Q2 could benefit from a ~100k pull-up resistor to the +ve supply to prevent possible leakage currents from causing spurious setting of the latch.
Prashant Zingade
Sep 7, 2016
9
Ok thanks i will try it.
Prashant Zingade
Sep 7, 2016
9
Capacitor is not required between Q1 base and ground ?
14,317
Q1 is pulled down, weakly though, by R2 and RL1. An additional resistor of ~100 kΩ may decrease sensitivity.
A capacitor will reduce sensitivity to noise (AC).
You may have to add both. Give it a try and play around with values to optimize the result.
Prashant Zingade
Sep 7, 2016
9
Added both 100k and 10uf/25v capacitor between base Q1 and ground. Circuit latch for 2 second and discount again.
Pl help.
Alec_t
Jul 7, 2015
3,821
You could add a 'supply missing' switch in parallel with SW2.
