semi OT- removing plastic lens from LED
George Herold
Hi guys, Is there a fairly easy way to remove the plastic lens on the 'standard' 5mm through hole LED? I've used a file to get ~90% down to the element, but I'm afradi if I go further I'll wreck it.
I tried some acetone but it did nothing. A chemical would be nice, but hopefully *not* methylene chloride.
Syd Rumpo
This may be folklore.
I often work with high-temperature stuff, and the wisdom is that you
can't use conventional LEDs at 180C because the lenses melt. I've never
needed to and haven't tried, but just maybe they'll soften sufficiently
to aid removal.
Some of the small SM ones seem to have Silicone lenses which it might be
possible to remove carefully under a microscope. Silicone oil will
soften Silicone rubber a little.
Cheers
Spehro Pefhany
Try hot (~85'C) red fuming nitric acid. You said a chemical would be
nice, but that is not a nice chemical.
Joerg
down to the element, but I'm afradi if I go further I'll wreck it. I
Johne Wayne would have put the LED on a fence post, step back 30ft, draw
and pull the trigger.
When looking at the 5mm through-hole LEDs I have here they are all fully
encapsulated, "immersed in plastic". And as John said, with the
placement precision all over the map. Not sure what you are trying to
design but you may be better off buying bare die. I don't know them,
just as an example:
http://www.tech-led.com/LED_die_bare_chips.shtml
George Herold
Can't you buy a flat-end LED?
Well, I'm using this red led as a light sensor. I was taking some data on response vs light intensity. (using a yellow led as a light source) And then I tried a green led (as a source) And though there were more photons I got a lot smaller signal. WTF I thought to myself, well maybe the red palstice lens is absorbing all the green light. So I filed it down and increased the signal by a factor of 5 or so... Now if I could just get more of itoff...
One problem with the lens-end ones is that the chip placement isn't
When hitting this with a file I'm afraid I'll 'take out' the little bondingwire and that will be the end of it.
George H.
George Herold
to aid removal.
Hmm OK maybe I can 'dig' around a bit with a soldering iron tip.
george H.
George Herold
"Arghhhh... Run Away!!" I've never heard of red fuming nitric acid but it sound like methyelene chloride would be safer.
George H.
George Herold
"I'd never shoot an LED in the back."
I guess I'm just going to have to settle for a bit of filing... I tried digging a bit out with the soldering iron and broke one.
George H.
Ecnerwal
George H.
Run, don't walk, to your nearest library that keeps old books, and get a
copy of "Some Birds Don't Fly" for a fuller appreciation of RFNA (and
quite a few chuckles.)
Spehro Pefhany
George H.
Last time I went to Home Depot I didn't see any consumer grade
methylene chloride.. has it been outlawed or something?
Joerg
Phil said:
You can get red LEDs in untinted packages.
Even whole tail light assemblies. But then you also need a lowering kit
and a major tchk tchk *BOOM* stereo.
Lasse Langwadt Christensen
Den fredag den 27. september 2013 00.54.12 UTC+2 skrev Phil Hobbs:
IPA will do that to many kinds of acrylic.
many types of acrylic craze and break in to little pieces
if it cleaned with any kind of alcohol
-Lasse
H
hamilton
Light Sensor ??
What does hacking an LED do that a regular "light sensor" won't do ??
h
George Herold
Light Sensor ??
h
Well this is a bit embarrasing since it's written by my boss.
http://teachspin.com/newsletters/TeachSpin_MAY13FINALFOR WEB.pdf
But basically it detects single photons. Which is way cool for ~$0.10.
This is all old news, but there's been a redesign to the elecronics box.. adding a voltage source (lm317) some series resistors and an LED light source. Yellow led's are great and greens stink.. visible light led's seem OK..so the spectral response is mostly unknown.* (I need a monochrometer... Well maybe just a wideband light source.)
George H.
*like being mostly harmless.
George Herold
Got it, I mostly found chemistry to be confusing.
George H.
to aid removal.
180C? RoHS reflow solder processes go up to 260C. Yeah, a lot of
LEDs melt there, but...
Spehro Pefhany
Cheers
Phil Hobbs
I've seen stress corrosion cracking in acrylic when PCBs were cleaned
with certain solvents. Nothing like the visible crazing but where
there were stress risers (eg. threads) cracks would gradually
propagate. This was in some very nice clear acrylic moldings we had
made for instrument faces. The problem was solved by baking off the
boards to remove small amounts of residual volatiles before assembly.
Best regards,
Spehro Pefhany
