sensitive electrometer
Robert Latest
No, they say 2fA on the front page, and the "typical" specs column
says 0.002 with the unit of pA on the far right side of the page.
So that's 2fA typical for the LMC660 and LMC662. Anyway, ignore
all that, we're relying on Bob Pease's remarks about these ICs.
What/where are BP's remarks about these ICs?
robert
Robert Baer
Winfield said:
Jonathan Kirwan wrote...
The 10^14 number is clearly far too conservative, e.g., having
been thoroughly beaten by NSC. My comment about using NSC's
chips to make measurements below 1fA refers to their low leakage
drift rate, which allows you to correct for the standing level
and then observe changes from that with a sensitivity below 1fA.
As far as a PCB is concerned, no-one would let this measurement
node anywhere near the PCB: I've used small teflon standoffs, as
well as raised-leg soldered-in-air connections, which works well.
...and had *no* triboelectric, accumulated surface charge orother
teflon-related problems?
W
Winfield Hill
Robert Latest wrote...
In various of his columns. He and his technician developed the
test setups for these opamps. I imagine he was involved in their
design as well. Didn't he have a few columns along the lines of,
What's all this Teflon stuff?
John Larkin
Specsmanship.
Inability to create a perfect plastic *all the time* - who knows.
In fact there are about 20 problems you may run into in the under-
100fA region, so watch out and don't have your expectations up too
high. I have written about 6 to 10 of the problems, and solutions,
if you search my previous postings here on s.e.d. Add the search
word Keithley to your Google advanced usenet search form.
If I pull a random 2N7000 out of stock (smallish mosfet, TO-92
package), and connect a supply and LED in its source-drain path, I can
tease the floating gate to barely turn on the led, then let it sit
with the drain lead hanging. The led stays part-on for days, and the
current must be in the 1e-17 amp range, ballpark 100 electrons/second.
John
W
Winfield Hill
John Larkin wrote...
I've done the same experiment, only with a 5.5-digit meter
measuring the drain current. It's clear the plastic packages
of these parts are essentially pefect when it comes to leakage.
Robert
Is that the one where test time was limited by cosmic rays passing through
the air volume by the inputs? He said something about the ionization left by
them created enough current to bugger the low input current test.
IIRC they had to make a little enclosure around the inputs to limit the
volume of air to be ionized by the stray whatzit and after that they could
reliably test the parts.
Robert
Robert
[snip]
John
You disconnect the drain "...drain lead hanging" supply?
Or you disconnect the Gate lead?
Robert
Robert Baer
John
Now *that* seems to be a good starting point for a rather sebsitive
electrometer!
Robert Baer
Robert
That also is the way i remember what ws said.
Robert Latest
On 9 Oct 2005 05:35:51 -0700,
Ah that. Yes, I remember. Thanks.
robert
John Larkin
That said, if the package itself is so good (and I read that you used
the word 'perfect' to possibly describe it), then why is it that the
better COTO relays tend to specify leakage resistances in the 10^12
ohms region?
[snip]
John
Robert
Gate of course.
John
Robert
John Larkin said:
message
On 8 Oct 2005 09:49:38 -0700, Winfield Hill
ohms region?
[snip]
John
Robert
Gate of course.
John
Whew!
Thought I was going to have to relearn some electronics.
Robert
Robert Latest
are you shure this is not caused by drain-gate leakage?
Could be, but two leakages cancelling each other out with such
precision would be rather improbable.
robert
