Series bulbs with rectified AC
duke37
Jan 9, 2011
5,364
14 months ago, I was volunteered to be the light string repairer. It took ages to find the dead bulbs or poor connections so I thought 'blow this for a lark' and I placed a 1N4007 in the plug to run the bulbs slightly cooler.
This Christmas one of the strings gave a short flash and died. The string is open circuit.
What would the effect of a diode be? Would the lower temperature give a longer life or the pulses vibrate the filament to destruction?
This technique is used to reduce the heat generated in AC/DC valve radios by using a lower dropper resistor.. Are the filaments likely to suffer?
Externet
Aug 24, 2009
944
I would say the filaments would run cooler and the 'vibration' would be half the amplitude, with at least 5 times life.
I use backyard incandescent 230V-200W bulbs fed by 120V instead of 120V-75W bulbs and so far, 10 years with no replacements. Did the same for a 120ft tall antenna tower red beacon.
If you feel uncomfortable with the diode, splice 2 strings in series, no diode, to the same voltage source.
dorke
Jun 20, 2015
2,342
In general,the life time of an incandescent bulb is mostly dependent on the number of it's turn-on times..
This is due to the fact that a cold bulb has much lower resistance than a warm one (by a factor of about 15!).
The much higher turn-on(cold filament) current shortens the life of the bulb dramatically.
And that is also the reason that bulbs mostly fail when they are turned on.
Putting a series diode in the AC path will create a half cycle feeding voltage to the bulbs.
Effectively halving the RMS voltage to the bulb.
It will increase life time dramatically while reducing the light intensity dramatically .
I think the pulsed nature will have no meaningful effect .
Reason being the bulb filament will not cool significantly in the half period time the diode isn't conducting
(10mSec ,for 50Hz).
A better solution would be to use LED strings.
dorke
Jun 20, 2015
2,342
Thanks Harald for the correction!
0.7 it is.
duke37
Jan 9, 2011
5,364
With half wave rectification, the filaments will run cooler and will have a lower resistance so the light does not go as low as might be expected.
Valve radios often use 6.3V heaters and dial bulbs, I replace failed bulbs with 8V bulbs and have not seen another failure but the use is not intensive.
