Setting idling current
K
Ken123
Hi...
I decided to check the idling current settings in a Denon AVR-3000. There is
a complicated process involving connecting a meter of test points,
adjusting intermediate voltage settings, then final settings of 3mv +/- .5mv
after 10 minutes .
I have the meter connected exactly as shown in the manual, but all readings
are negative, not positive. Could the manual be in error about this??
Ken
Eeyore
after 10 minutes .
Is the speaker load still connected ? That can cause errors measuring idling
current.
Otherwise, yes , I'm sure the manual could have got it wrong. If you understand
the circuitry you may be able to deduce it from that.
Graham
K
Ken123
idling
current.
understand
Graham
Yes, I left speakers disconnected as per the instructions. I'll study the
schematic. Thanks.
Charles
Ken123 said:
Hi...
is a complicated process involving connecting a meter of test points,
.5mv after 10 minutes .
readings are negative, not positive. Could the manual be in error about
this??
If the absolute values are as expected, it could simply be meter polarity.
Sure, the manuals are often wrong and backwards :>)
Trevor Wilson
Ken123 said:
Hi...
after 10 minutes .
**Hint: THAT is not a complicated process. It is one of the easiest
things you can do. Try tuning up an analogue tuner sometime.
**Swap the meter probes over. In the final analysis, it doesn't matter
anyway. Just adjust for the correct absolute value. Positive or negative
is unimportant.
Trevor Wilson
Jerry G.
In all praticality, if the polarity was really incorrect, the amp
would be having problems.
If you do mess with the bias adjustments, make sure that there is no
DC to the speaker outputs with no load. Also check that the DC voltage
ballance is correct.
Refer to the service manual for details. I am speaking genericaly
here, and not model specific.
The service manual should have the proper set-up info for your amp.
Jerry G.
K
Ken123
Jerry G.
I was pretty much thinking along the same lines. I'll just follow the
instructions and ignore the minus sign. Thanks.
Ken
