SG/UC3525 problem resolved
Pooh Bear
Thanks to everyone who contributed to the previous thread concerning my
mismatched timing periods with this PWM smps chip.
The culprit was indeed the shutdown pin.
I see now what happened.
I followed the guide to use of the shutdown pin in the 'lab test
fixture' diagram. The *only* diagram in fact that shows it's use.
That shows shutdown activated by connecting the shutdown input to Vref
via a 2k resistor. To *enable* normal operation the pin is open ( indeed
it's connected to the 2k resistor which is now floating ) - which the
text says contradictorily earlier that you shouldn't do !
Some bright person spotted that a recent copy of a TI data sheet
correctly shows the shutdown input tied to Vref by a resistor ( 5K for
some reason in this case ) and the chip enabled by *shorting shutdown to
ground* !
I perused many data sheets including TI, STM, Motorola, On-semi's
version of same and *all* make the same mistake of showing pin 10
floating in active mode. Only a recent data sheet for TI's 3525A gets it
right - even the data from TI for the 3525B enhanced version gets it
wrong again *and* an earlier rev of TI's 3525A also shows the wrong
method !
Can you believe that ?
Just to make things more interesting the internal block diagram of the
3525 in 'lab test fixture' mode is different to the one given earlier in
the data sheet and gives an erroneous impression of how shutdown is
internally connected and how it functions - see the connection to the
PWM latch. This error is replicated in *all* the data sheets I've seen
including the one with the correct pin connection !
Phew !
Thanks to all for sorting that one for me.
Shorting shutdown to ground to enable operation avoids the noise pickup
of course.
Cheers, Graham
K
kell
ground* !
method !
Phew !
of course.
Cheers, Graham
Agree on all fronts. 3525 data sheets all copy each other, and they
suck. And I had the same hassle figuring out I had to ground pin 10...
Mac
[snip]
of course.
Cheers, Graham
Thanks for following up with the resolution. I'm sure it will save some
other people a lot of trouble when they have a similar problem and search
google groups. ;-)
--Mac
Pooh Bear
[snip]
of course.
Cheers, Graham
YVW ! The least I could do.
google groups. ;-)
I'm actually intending to contact all the relevant semiconductor vendors and
request they amend their data sheets ( with a *big* erratum message ).
Graham
legg
ground* !
method !
The UC3525A data sheets were generated in the mid 80s, to illustrate a
replacement part for Silicon General's SG3525 (already obsolescent at
that time) and SG3525A. Your 'correct' lab bench test shutdown
hook-up method shows up in the earliest 'A' version Unitrode data
sheets, which TI adopted.
The 3525B appeared in the mid-90s. As the B version only represented
a process-tightening, I doubt that there was any great effort to
generate app notes in excess of those already present (eg U89 last
published in IC500 in '87).
The shut-down pin in Unitrode A and B versions was usable as a crude
high speed latch in pulse-by-pulse limiting. As such it presented
application advantages over the 3524 and 3525, which were either slow,
unlatched, or both.
Lab bench open-loop test layout is intended only for that function,
and both will probably work as described, to demonstrate the improved
features. I note that this part's sheet was last revised in '04, but
most likely only to ease electronic publication and storage.
Most power supply designers will become aware, fairly early on, that
noise immunity is improved when localized low impedances are provided
in victim locations - this includes all IC input pins. Open circuit
input pins are seldom a good idea in a noisy environment.
You have discovered one of the advantages that accurate physical
breadboards display over electronic simulations.
RL
