In "your" circuit, you have pins 12 & 13 tied to the drain of the MOSFET... I think they should be tied to either Vref or to Vin unless in your final design the Vin voltage will be to high for MOSTFET driver.
While you could use this voltage mode control PWM (SG3524), it's considered "old" in the industryand there are better PWM's out there that are specifically made for Buck converters (for both synchronous and non-synchronous configurations) and won't need a driver IC, as bootstrap circuitry is onboard for driving high side FET's.
Can you tell us a little more about your design?? i.e. input voltage, output voltage, switching frequency, expected ripple current, output ripple voltage and since this is a voltage mode controller the minimum load current (this will directly impact the inductor value)... etc.
Your IRF540 is big time overkill for a 15V input voltage... is it needed or is it something you just happen to have on hand?
