Shake Flashlights power
rebert3
Jun 27, 2017
If you increase the Guass of the magnet will also increase the power generated? I have this silly idea of trying to make a human powered electric vehicle via Fraday power. :)
14,487
increase the magnetic field strength or increase the shaping movement ... yes
what sort of vehicle ?
I suspect you will find that extremely difficult as a person cannot sustain the input power requirements for very long
I have seen threads on this before and the amount of power/energy an avg person can generate through arm/leg movement
before tiring .... it isn't a lot
Others may remember said threads or other related info
Converting motion into electrical power than back to mechanical motion loses power in both directions. You will not create a human powered vehicle that way that is as efficient as a bicycle.
shrtrnd
Jan 15, 2010
3,902
... why am I thinking this thread is eventually going to wind-up in our new 'twilight zone'?
I also have seen articles and references considering this. I think it's a part of the human condition, you
should know however, that you're not the first to imagine what you want to do.
The interesting thing I have noticed though, is that over the years mechanics and electronics has advanced so
much, that many things originally considered impossible, are now found to be potentially attainable.
Who knows, maybe we'll be seeing an answer for you here in a few years.
FuZZ1L0G1C
Mar 25, 2014
366
To illustrate @BobK 's point:
A 12V dynamo is connected to a DPDT relay, which feeds a heavy load (bank of lamps).
Dynamo is operated via pulley/belts by turning a crank.
No load - smooth sailing, easy to crank.
Energise relay (load connects) - suddenly you're "straining" against the dynamo & work-load.
(This was one of our school/science projects).
The E** series of electric locomotives use this feature for electrical braking,
forgot now what it was called (c. 1980's).
Hybrid cars also use this method for braking, using the generarted power to charge the batteries.
Dynamic braking.
