WRONG. You have failed to notice that car was 3.64 metres in length and thus the answers are out by a small factor that involves the speed of light in an imperial universe.
Darn, always those little details...
Danny, in case you've given up, the answer to Questions 4 and 5 are (in no particular order) 9V and 0V. Can you figure out which answer goes with which question? The switch acts as a short when it is closed.
http://www.falstad.com/circuit/#%24+13+5.0E-6+10.20027730826997+50+5.0+43%0Aw+192+352+464+352+0%0Av+192+352+192+192+0+0+40.0+9.0+0.0+0.0+0.5%0Ag+192+352+192+416+0%0Ar+464+352+464+192+0+3141.5899999999997%0As+192+192+336+192+0+1+false%0Aw+464+192+336+192+0%0Aw+192+128+192+192+0%0Aw+464+128+464+192+0%0Aw+192+128+240+128+0%0Aw+416+128+464+128+0%0Ap+240+128+416+128+0%0A
If Vcc to Ground Is Shorted, How do I find which stage is causing the SHORT to Vcc To Ground?
To Find a short from Vcc to ground, you have to turn the power OFF?
And use a DVM ohm meter to measure if there is zero ohms at any stage of the circuit?
If the Vcc to Ground Are Rails or Bussed, If i put a ohm meter across the Vcc to ground anywhere in the circuit or stage it will measure zero ohms if there is a short
How do I know which stage of the circuit is the faulty stage that is causing Vcc to ground short?
Do I have to Disconnect each stage of the circuit one by one from Vcc?
move the probe along the gnd and/or vcc tracks until the resistance reaches a minimum value
If there is a DEAD SHORT from Vcc to ground, won't all the stages measure zero resistance?
Cause If I take my probes and measure the Vcc to ground for each stage , won't they measure zero resistance because its a Dead short from Vcc to ground?
Give me the resistance across the rail side (point A & B)
and then give me the resistance across the stage one side (point C & D).]
Zero Ohms
Zero Ohms?
YES?
Right
Wrong
Wrong
Are you sure? I would think the zero ohms short would TAKE OVER since its the least path for current
So ONLY the faulty stage will measure zero ohms?
