Lauri Alanko
- Jan 1, 1970
- 0
Hello.
As we know, it is a historical accident that the charge of the
electron is considered negative, and conventional current flows
counter to the electrons. For a long time I thought that this wasn't
of any consequence, since all the math was symmetrical: everything
would work the same if we inverted the signs.
But with semiconductors this isn't true. Electrons are more mobile
than holes, and that is why NPNs are in general a bit better than
PNPs, and N-channel mosfets are better than P-channels. Ideally, we'd
always choose the polarity of a circuit so that we'd primarily get to
use N-type transistors.
However, there is another asymmetry that can prevent this, and that is
the distinction between the ground and supply rails. "Ground" is the
potential level that is connected to the chassis and possibly to
earth. Sometimes, because of safety or EMI reasons, we want a circuit
to be tied to ground, and that's why switches have to be high-side.
But due to convention, high-side (i.e. non-ground-side) is at a
positive voltage relative to ground, meaning that we either have to
use P-type transistors or then resort to complex bootstrapping
gimmicks (boost capacitors).
So let's summarize:
* Physics says we should switch on the negative rail
* Safety says we should switch on the non-ground rail
* Convention says these two rails are distinct
To me this seems to imply that if compatibility with conventional
circuits is not an issue, we'd be better off tying our positive rail
to ground and calling the negative rail -V, and then doing easy, safe
switching on the negative rail with N-type transistors. As an
additional bonus, the flow of electrons in the circuit would finally
seem natural.
Do I have this right?
Lauri
So let's summarize:
seem natural.
Lauri
