shaiqbashir
- Jun 4, 2005
- 251
- Joined
- Jun 4, 2005
- Messages
- 251
Hi guys!
well! suppose that i have a tunnel that is having a slope i.e. When a tennis ball is inserted from its top end, it automatically floats to the bottom end and comes out of the tunnel due to slope.
Now if i insert, lets say 8 balls in that tunnel one behind the other, so the balls will come out one after the other due to slope.
Now if i want to stop the balls from coming out, i need to use some door or shutter type of thing, that can be opened or closed as required. When it is closed, no more balls should be able to drop and when it is opened, the balls start dropping one after the other.
I want to control that shutter through a motor, and this motor will be connected to my PIC. That is i want to run this motor through programming in order to make the shutter on and off when required.
I want to ask you that what should be the best mechanism that can be employeed for this purpose?
Thanks in advance!
Take cares
Good Bye!
Thanks in advance!
Take cares
Good Bye!
