Silicone Potting Compound
BeeJ
I need to quickly find some silicone potting compound. Do not want to
order anything 'cause I need it today.
Of course can't use regular caulk since it contains acetic acid.
So how about fish tank silicone sealant?
What else will work?
I am potting the leads where they are soldered to a miniature
microphone.
Phil Allison
"BeeJ"
** Works fine.
** Two part Epoxy glue - like " Araldite ".
I am potting the leads where they are soldered to a miniature microphone.
** Either of the above will do - but 5 minute Araldite is damn quick.
..... Phil
Jasen Betts
yeah, or any other neutral cure silicone (eg: roof and gutter)
Automotive body putty (but not the metal filled stuff),
and other similar 2-part fillers as long as they don't shrink on
conduct electricity.
Urethane based caulks.
microphone.
If it's just for strain relief I think there's a locktite product
also hot-melt glue.
or an elastic product like vinyl flooring adhesive, or panel ahdesive
Bob Masta
also hot-melt glue.
I've become a big fan of hot-glue for projects like this.
Even allowing for the really long warm-up time of my cheapie
glue gun, it's still way faster than waiting for any other
type of glue to dry or set. It also has the advantage of
being "tough"... strong without being brittle.
I've even used hot-glue to turn little "sky wired" circuits
into durable finished projects, where looks aren't an issue.
Best regards,
Bob Masta
DAQARTA v6.01
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Scope, Spectrum, Spectrogram, Sound Level Meter
Frequency Counter, FREE Signal Generator
Pitch Track, Pitch-to-MIDI
Science with your sound card!
BeeJ
BeeJ wrote on 4/25/2011 :
I need to quickly find some silicone potting compound. Do not want to order
How about if I narrow the field a bit and need:
Tough
Flexible
Repairable
Small tube
Available from Target or K-Mart or the like.
Thanks for the suggestions so far.
steamer
--What he said: hot glue. One trick: while it's still hot slide heat
shrink over the area, then heat it up until glue oozes out of both ends,
then it's neat and watertight.
Tom Biasi
"BeeJ" wrote in message
Tough
Flexible
Repairable
Small tube
I like some of the other suggestions better but another option to fit your
specs is GB Liquid Tape, available in a few electrical colors and is at Home
Depot and Lowes.
Tom
Jasen Betts
Tough
Flexible
Repairable
Small tube
hot glue, or 2-part epoxy.
available at most supermarkets.
