Simple BASIC microcontroller programming question
sommes
I would like to input 10 bit from port B pin 0, 1, 2, 3 and output it to
port D pin 2, 3, 4, 5, however, my code seem doesn't work. Could you guy
please give me some idea and point out the mistake. Thank you very much
Bascom AVR complier, Atmel AT90S8535.
The code is shown as below
$regfile = "8535DEF.dat"
$crystal = 8000000
Config Portb = Input
Config Portd = Output
Dim R As Word , W As Byte
Do
Ddrb = &B11110000 'set pin 0,1,2,3
as input
R = Portb
Ddrd = &B00111100 'set pin 2,3,4,5
as input
Portd = R
Loop
End
sommes
Thank you Alan, I've try to PinB before, but the value seem is not correct.
Correct output can show from 0-9 in 7 segment display, but this one only can
only show 0-3.
I knew it is little bit hard to understand my
Situation.
Thanks anyway
