Simple capacitor question
Mustwin351
Apr 10, 2013
49
When you have a capacitor between your two inputs on an alternating current circuit (i.e. possibly a power supply) why does that not create a direct short?
What am I missing? If a capacitor passes ac voltage why is that not like a line to line short?
Gryd3
Jun 25, 2014
4,098
A capacitor can appear as anything from a short to a very high value resistor depending on the frequency and capacitance.
There is a formula for it...
Xc = 1 / (2*Pi*f*C)
Xc = Capacitive reactance (Ohms)
Pi = 3.14159.....
f = Frequency (Hz)
C = Capacitance (Farads)
14,486
A capacitor doesn't pass AC as such .... as in NO current flows directly between the 2 plates
Rather each plate alternately charges and discharges
And as Gryd3 said, it will "act" as a short circuit dependant on the info he gave above
Mustwin351
Apr 10, 2013
49
Thanks guys I recall that now.
For a power supply the capacitor goes on the "dc" side or the circuit and no matter the reactance of the cap you won't have a short. Instead it just "charges" the capacitor.
It's been sometime since school. Thank you.
Mustwin351
Apr 10, 2013
49
Great link Dave. Thanks!
It states that in order to use a bridge rectifier for full wave rectification that a center tapped transformer must be used...but it then refers to figure 1.1.3 for this which does not have a center tapper transformer.
Is this just a mistake in figure 1.1.3?
http://www.learnabout-electronics.org/PSU/psu11.php
Mustwin351
Apr 10, 2013
49
You are looking at figure 1.1.4 The Bridge Rectifier that has no center tap and 4 diodes.
Figure 1.1.3 certainly does have a center tap on it's secondary and is using two diodes.
So figures:
1.1.4
1.1.5
1.1.6 should all have center taps on the transformer secondaries connected between the two diodes correct?
I guess without a center-tapped transformer the best you can achieve is half wave rectification?
Gryd3
Jun 25, 2014
4,098
So figures:
1.1.4
1.1.5
Nope.
1.1.4
1.1.5
1.1.6
Are all using a Bridge Rectifier which does tot require a center-tapped transformer secondary.
1.1.3
Is using 2 diodes, and requires a center-tapped transformer secondary to rectify a full wave.
This was a misunderstanding. The page correctly refers to figure 1.1.3 which had 2 diodes and a center-tapped transformer, but you had accidentally looked at 1.1.4 instead which is the first figure to use a bridge rectifier.
Mustwin351
Apr 10, 2013
49
I gotcha now. Sorry a little further reading would have helped. The center tapped transformer with a rectifier is just more efficient than one without a center tap.
Thank you very much!
14,486
you still might be misunderstanding ... the way you just wrote that is misleading and not what the www page said ;)
they said ....
If a transformer with a centre tapped secondary winding is used, more efficient full wave rectification can be used. The centre-tapped secondary produces two anti-phase outputs, as shown in Fig 1.1.3.
they are telling you its more efficient that a single winding transformer and only ONE rectifier diode as referenced to in Fig 1.1.2
A single winding secondary and a bridge rectifier is still efficient. and has the advantage of full wave rectification without the need for a centre tapped secondary :)
