Simple & cheap 'off line' power supply?
Rolavine
I need to make about 24 volts DC (good enough for dc relays) at about 250 ma
maximum from either 110v or 220v ac input.
I've found a bunch of circuits online, and quite a few chips.
I would like to avoid using a switcher because of EMI.
I think I need too much current for a shunt type approach.
Does anyone know of any simple SCR based, 'light dimmer' type circuit that can
be used for an off line supply. I have a PIC onboard that has a battery back
up, so it could run the SCR? I just looked up sensitive gate SCR's and it
didn't even seem impractical that I could trigger it through a capcitor?
Any other advice on a best cheapest approach would be helpful. I've done these
before for cheap control circuits but have never needed this much current
before.
Rocky
Rocky
Active8
Er...
If you mean "divider", 2.5 A through the divider.
A triac uses both half cycles. Both give EMI in the simplest
circuits. Hint: thyristor data book.
I don't like to recommend an offline supply that's not isolated,
something easily afforded in a switcher - and your batt backup might
power the controller. Or a PVI opto isolator driving the thyristor,
I guess.
Spehro Pefhany
before.
Rocky
For 250mA, use a transformer.
Best regards,
Spehro Pefhany
F
Fred Bloggs
You can't beat something made out of junk TV parts- this circuit should
suit you well:
View in a fixed-width font such as Courier.
Rolavine
Date: 11/18/04 6:55 AM Pacific Standard Time
suit you well:
. RG
. FW BRIDGE | |
. +--------+ R | SCR |
. | -|>|- | | | | | comp/one-shot
. | c ---/ +-----|+/ |
. | HV \| // \ 24V | |/ |
. | xstr|--+ --- | + |
. | e | | |BFC |
. 100us
Great circuit, I think, where did you get it from? It was exactly the kind of
thing I was thinking about.
Rocky
