Simple dB meter driver circuit.
electronics_shamim
Mar 21, 2007
77
Sirs,
Does anyone have complete schematic or part list required for a simple dB meter driver built around transistor/IC?
Regards,
Shamim-India.
audioguru2
Apr 6, 2004
12,026
Here is a pretty good VU meter made with an LM3916 IC. I made some similar circuits with an LM3015 IC instead that displays 3dB steps. The datasheet shows how to cascade two ICs for a 60dB range.
EDIT: OOps. Here it is:
electronics_shamim
Mar 21, 2007
77
Dear Audioguru,
thanks for your immediate response. You have sent me the vu meter built around (LEDs). The circuit i need is different.
I mean to say that after the pre-amplifier out, it should be connected and the vu meter  called db meter has the needle deflection, not LEDs.
I hope you understand by now. However, I appreciate your immediate response and guidance.
Regards,
Shamim_India.
audioguru2
Apr 6, 2004
12,026
Hi Shamin,
I have not seen a dB meter with a needle for about 30 years.
electronics_shamim
Mar 21, 2007
77
Sir,
I hope I have not clarified properly. Now to be clear I state like this:
Like in an analogue multimeter (the needle deflects, in terms of ohms measurement, voltage etc.). So, a dB meter or the so called vu meter is also like that, in which the needle deflects (dancing) in rythms in relation to the speaker sound. For each channel it is there in the front panel top right hand side mounted unto the tape deck.
I hope this time i have clarified you properly. Hope to receive a reply this time.
With regards,
shamim
audioguru2
Apr 6, 2004
12,026
I haven't seen a tape deck for about 15 years. My cassette deck had LED VU meters.
MP1
Dec 7, 2003
3,399
Shamim,
Are you looking for something like this?
(click on the picture to enlarge it.)
MP
audioguru2
Apr 6, 2004
12,026
The meter circuit posted by MP is a frequency meter, not a VU dB meter.
A VU meter shows audio levels, not the frequency of a tone.
electronics_shamim
Mar 21, 2007
77
Sir,
The reply posted by RDL2004 is the exact one which I wanted. A simple vu meter depicted therein by use of diodes is also fantastic. I wish to extend my sincere thanks to him for the efforts made to post me the same.
Thanks again with regards,
shamim_india.
MP1
Dec 7, 2003
3,399
Ooops! Sorry about that Shamim. I attached the wrong drawing when posting. Thanks to RDL2004, it looks like you have what you are looking for. It is still simpler than the one I meant to post. Best of luck with your project!
MP
electronics_shamim
Mar 21, 2007
77
Sirs,
I wish to have still more simpler db/audio peak level meter which can be interfaced just at the output of of pre-amplifier wired around BC148, which I had seen some years back, but I do not have the Circuit. Any idea pls.? However, I am very thankful to RDL2004, who has guided me properly.
Thanks to Audioguru, who has been always kind to extend help.
Thanks to MP who keeps me updated on immediate response.
Regards,
Shamim_India.
MP1
Dec 7, 2003
3,399
Shamim,
I do not think you will find one simpler than the design with diodes that RDL posted. Still, with this one you do not have very good accuracy.
MP
