Simple home project
SJCollier
Dec 17, 2025
3
Hello and thank you in advance. I have six LED lighted Christmas houses. Each one has four LED's in them. They are each powered by two AA batteries. I'd like to hard wire them using a wall wart. If I wire them in series what voltage requirement would I need? (18V?) I plan on using a regulated supply. Also, would a 1 amp supply be adequate?
Martaine2005
May 12, 2015
5,318
Yes, 18V if in series theoretically.
But I would have them in parallel. Approximately 240mA total if they’re a typical 10mA or better, lower.
3 volt walwart (adapter) @ 300mA for a little head room.
The above assumes the two AA batteries are in series.
SJCollier
Dec 17, 2025
3
Thanks! Yes, the batteries are in series.
danadak
Feb 19, 2021
1,104
Have you measured their current consumption when powered by batteries ?
Clearly you want to operate them to their design ratings, eg. run them at design current
levels.
SJCollier
Dec 17, 2025
3
They're white LED's so they draw about 20ma so with x24 about 480ma so I figured a 1 amp wall wart would work fine
olivia_49
Dec 26, 2025
24
If each house runs on 3 V, series wiring would need 18 V, but that’s risky, one failure and all go out. It’s safer to wire them in parallel with a 3 V regulated supply. Six houses at ~50 mA each need ~300 mA, so a 1 A supply is plenty.
