I'm about to my witts end on a simple project.
I'm trying to install Radio Shack red blinking LEDs on my Lionel layout.
They are rated at 20ma, 5 volts and I have a 13 volt AC power supply.
From what I have learned, I need a 400ohm resistor and a DC power supply.
Correct?
Here are my questions,
1. The LED is rated at 2.5 to 5 volts.
In one setup, I had 2 LEDs in parallel and a 680ohm resistor in series before the first LED.
It worked ok, but then I accidently applied 15v AC which blew the LEDs with pop!
Now, I can't get one (new) LED to work with the same resistor, which worked in the past.
Any ideas?
2. Will 13vAC with the LED in series with a 680ohm resistor damage the LED?
3. Is it possible to power the LED with a 680ohm resistor and a diode in series using 13vAC?
Correct?
Any ideas?
