Simple line level amp circuit for auto application?
Scott MacLean
I've hack-installed a satellite radio receiver into my car's factory stereo,
however the line level output of the receiver is nowhere near the level
required to drive the receiver happily. The end result is that when
listening to the satellite, the receiver's volume has to be at or near
maximum, which means it is amplifying all the low level noise and crap along
with it.
I'd like to put a simple line level amplifier in there to solve the problem,
obviously running off the car's 12 to 13.8v supply, and being relatively
immune to external noise. Years ago when I did this sort of thing I would
have used a 741 op amp, but I understand there are far better solutions
(sonically) nowadays - a 5532, perhaps?
Anyone have any suggestions as to components and circuits I could use, or
better yet, a proven kit I could put together?
Thanks...
W
Watson A.Name - Watt Sun, Dark Remover
with it.
Have you checked to see if it might be a loading problem? In other
words, are you trying to drive a low impedance input with a high
impedance output? If so, your amp may not help at all if it is also a
high Z output. And all you might need is something to match the
impedance. A pair of transistors in an emitter follower circuit might
do just what you need, yet they could be put in the existing circuit.
Another thought is that a simple matching transformer might also work.
Thanks...
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
Similar threads
