Hello Guys!
I'm doing a O2 meter for my car because pay about $150 bucks for a simple meter will not do for me, too much. So, i want to build a meter with 2 LM3915 for better resolution but i have a few questions:
1 - the car voltage is too unstable, there is too much oscilation, mechanical relays turning on/off, sparks, so i will use a 7805 to regulate the 12v. But there is one more thing, how to protect the 7805 from over voltage at the input from the car electric system?
2- In the National LM3915 datasheet there is a way to make the display to flash if the "warning" led lit up (Bar Display with alarm flasher), how to make this work with 2 LM3915?
3- The signal from the lambda sensor came with some noise, so grounding the signal with a 1M ohm resistor with a 1n capacitor could filter that with out killing the signal? Suggestions?
