Simple SM Resistor Question, and Fuse Question
Jeff Walther
I am trying to identify some surface mount resistors, without desoldering
them and measuring them. The markings on them are 75R0. I am guessing
this is 75 ohms. Is this correct? I am used to the ones with three
digits where the third digit is the tens exponent. I've never seen one
with an R inserted into the number before.
Second, any idea what a P 075 on a SM fuse means? The P is the top line
and it might be a rho. the 075 is on the second line. Or an LF 075 with
the F sitting inside the L and the numbers and letters all on one line.
The fuse is about a size C or D if this were a SM capacitor.
I guess while I'm here. I'm also looking at some tiny SM ceramic
capacitors. Looks like a size 0603 but there are no markings on them of
course. Do I just have to pull those off and measure them to get a
value? These are near the VGA connector of a video card. I don't have a
capacitance meter, although I do have a digital multimeter that measures
V, I and R. Is there any way to measure those without springing for a
capacitance meter? I seem to remember something about using the RC time
delay. Or recommendations on an affordable capacitance meter?
Thank you for any helpful or humorous comments.
Michael A. Terrell
them and measuring them. The markings on them are 75R0. ^^^^^^^^^^^^^
I am guessing
value?
Some have an almost invisible two character marking that can be read
under high magnification. On the other hand, if the manufacturer was a
cheapskate, they but the cheaper, unmarked version.
There are quite a few capacitor meters, from simple add on kits
(Ramsey, Rainbow, etc.), to kits like the AADE unit (also available pre
built)
We now return you to our normally scheduled programming.
Take a look at this little cutie! ;-)
http://home.earthlink.net/~mike.terrell/photos.html
Michael A. Terrell
Central Florida
Peter Bennett
I'd guess 75 mA
LF would be Littlefuse - a well-known maker of fuses. Have a look
around their website at http://www.littlefuse.com
Jeff Walther
Thank you, Michael and Peter.
I hope that folks will be as kind for one more question. I am looking at
another component that looks like a SM transistor in an SOT-23 package,
however the silk screening on the board says "REGn" where 'n' is an
integer. There are six pads, three to a side, but the components in place
appear to only have three pins as for an SOT-23 package. In other words
three pads are unused, three pads are used. The components is marked
K043. Any idea what this is?
Thank you.
