OK, this circuit should fill your requirements. Back when Radio Shack actually stocked parts I would select certain components on the basis of what they commonly stocked. This was to make it easier for nubes and casual electronics builders to obtain parts. You can still check for RS availability or a UK member can point you to a supplier. Ebay is another source that I often use.
Note that I didn't include a part number for the PhotoTransistor (FT1). I used a generic model for my simulations. Some components have parameters that make them popular over others. Hopefully someone here will suggest a common and popular part number.
Because you're using a 9V battery I chose CMOS chips to keep your battery drain low. Therefore, the LEDs are the only components that draw any appreciable current. Most LEDs will appear brightest when viewing them directly from their top. You can lower battery drain by increasing the value of R4 at the expense of brightness. You may find that a value of 1K to 2K will suffice.
I've included 3 switches. A power On-Off switch and two momentary push buttons. The "Step" push button manually advances the 4017 counter and lights the next LED. The "Reset" push button resets the count to player 1 regardless of which LED is currently lit.
Any and all critiques of this design are welcome.
Chris
Chris
