Hi Thanks for reading. Okay I want to build a simple audio amplifier with absolute minimum components.
So far with my amateur attempts i have built a single stage amplifier using a 2sc5200 transistor, with a 1uf capacitor and 1000 ohm resistor as an input stage, but it sounds like a glorified headphone amp, very little output about half a watt.
Do you have any minimal component designs which can put out about 5 watts, or if this is not possible a two stage amplifier consisting of a driver transistor followed by an output transistor, again minimal components. I have 2sc5200 transistors so will appreciate any designs incorporating these.
