Simplest debounce for NO switch?
SA Dev
I currently have a normally open switch that I need to debounce. It needs
to be connected to a device that expects normally open, and then two wires
shorted when the button is pressed. What is the easest/simplest way to do
this?
SA Dev
mikem
What is the open-circuit voltage across the switch?
What is the current that flows through the closed switch?
MikeM
SA Dev
Hi Mike,
5V
<1 mA
Thanks!!!
SA Dev
mikem
SA said:
Hi Mike,
<1 mA
The best way to debounce a switch is to use a form C switch, and
cross-connected logic gates to create a Set-Reset Flip-Flop.
In your case, you have only a form A switch. Your pullup resistor is
something like 5K. (5v/1mA)
I'm assuming that the voltage across the switch goes into a CMOS input
with a logic threshold of ~2V.
Most switches "make" multiple times for durations of 10 to 250us or so
with "breaks" of durations of ~100us of when pushed.
Attached is an LTSpice simulation which uses an RC network to establish
some relevant time constants which filter out multiple transitions. This
is not 100%; but is better than nothing. Run the simulation and look at
Node S.
If you have a better guess at the switch bounce behavior, then you can
edit the PWL. The 47 Ohm resistor is there to limit the capacitor
discharge current to prevent damaging the switch.
MikeM, PhD EE
--------- Cut and paste into a file called DeBounce.asc -----------
Version 4
SHEET 1 2164 680
WIRE -176 240 -176 416
WIRE -176 416 -80 416
WIRE 96 416 96 304
WIRE -128 64 -176 64
WIRE -176 64 -176 160
WIRE -48 64 -16 64
WIRE 96 64 96 96
WIRE 96 176 96 224
WIRE -16 384 -16 416
WIRE -16 416 96 416
WIRE 48 240 -80 240
WIRE -80 240 -80 416
WIRE -80 416 -16 416
WIRE -16 304 -16 288
WIRE -16 288 0 288
WIRE 96 64 144 64
WIRE -16 64 96 64
WIRE -16 416 -16 448
WIRE -16 96 -16 64
WIRE -16 160 -16 192
WIRE 224 -32 96 -32
WIRE 96 -32 96 64
WIRE 288 -32 432 -32
WIRE 0 288 48 288
FLAG 144 64 s
IOPIN 144 64 Out
FLAG -16 192 0
FLAG -16 448 0
FLAG 432 -32 B
IOPIN 432 -32 Out
FLAG 0 288 c
SYMBOL res 80 80 R0
SYMATTR InstName R1
SYMATTR Value 47
SYMBOL Misc\\battery -176 144 R0
WINDOW 123 0 0 Left 0
WINDOW 39 0 0 Left 0
SYMATTR InstName V1
SYMATTR Value 5
SYMBOL sw 96 208 R0
SYMATTR InstName S1
SYMATTR Value msw
SYMBOL voltage -16 288 R0
WINDOW 3 126 68 Left 0
SYMATTR Value PWL(0 0 99u 0 100u 1 200u 1 205u 0 308u 0 310u 1 510u 1
515u 0 718u 0 720u 1 822u 1 825u 0 928u 0 930u 1 1200u 1 1205u 0 1310u 0
1330u 1 1425u 0 14000u 1)
SYMATTR InstName V2
SYMBOL res -32 48 R90
WINDOW 0 0 56 VBottom 0
WINDOW 3 32 56 VTop 0
SYMATTR InstName R2
SYMATTR Value 5k
SYMBOL cap -32 96 R0
SYMATTR InstName C1
SYMATTR Value 0.22µ
SYMBOL Digital\\buf1 224 -96 R0
WINDOW 3 22 98 Left 0
SYMATTR InstName A1
SYMATTR Value Vhigh=5
TEXT 214 402 Left 0 !.tran 3m
TEXT 176 312 Left 0 !.model msw SW(Ron=0.1 Roff=100Meg Vt=0.5)
TEXT 224 64 Left 0 ;Switch Debounce simulation
TEXT 224 112 Left 0 ;Note: R2 is the pullup\n R1 limits
discharge current\n Node S goes to the CMOS input
mikem
Node S.
MikeM, PhD EE
Version 4
SHEET 1 2164 680
WIRE 96 416 96 304
WIRE -48 64 -16 64
WIRE 96 64 96 96
WIRE 96 176 96 224
WIRE -16 416 96 416
WIRE 48 240 -80 240
WIRE -16 288 0 288
WIRE 96 64 144 64
WIRE -16 64 96 64
WIRE -16 96 -16 64
WIRE 224 -32 96 -32
WIRE 96 -32 96 64
WIRE 0 288 48 288
FLAG 144 64 s
IOPIN 144 64 Out
FLAG -16 192 0
FLAG -16 448 0
FLAG 432 -32 B
IOPIN 432 -32 Out
FLAG 0 288 c
SYMBOL res 80 80 R0
SYMATTR InstName R1
SYMATTR Value 47
SYMATTR InstName V1
SYMATTR Value 5
SYMBOL sw 96 208 R0
SYMATTR InstName S1
SYMATTR Value msw
SYMATTR InstName V2
SYMATTR InstName R2
SYMATTR Value 5k
SYMATTR InstName C1
SYMATTR Value 0.22µ
SYMATTR InstName A1
Tim Wescott
Node S.
MikeM, PhD EE
-- snip --
A simple low-pass into a gate can still bounce, unless you go into a schmidt
trigger. This can cause many long and frustrating evenings.
Tim Wescott
If you have no microprocessor the electrically simplest debounce is probably
a low-pass filter into a schmidt trigger. Beyond that there's scads of
electronic debounce schemes to be found on the net.
If you're feeding a microprocessor the (electrically) simplest debounce is
to do it in software. This can be as easy as sampling the switch at an
interval longer than the switch bounce time, with complexity increasing from
there. The best software debounce routines will monitor the switch state,
keeping track of the state, the last state and the time from the last
transition, and will (a) give you a switch event right when it first
occurrs, and (b) not give you any false events.
CBarn24050
a 555 and capacitor is quite reliable, a quick search should find a circuit.
F
Fred
SA Dev said:
this?
SA Dev
Is there a response and recovery time spec for this.
I recall making a circuit similar to this for electronic ignition where I
still used the contacts. I used a diode to make the break part very fast
with a parallel resistor for a slow "recovery". This coupled with a
capacitive filter and a Schmitt trigger ensured a clean no bounce output.
It worked very well.
Your circuit is easier where the contacts make you can quickly discharge a
capacitor through a diode and any bounce could only bleed a small current
(through a resistor in parallel with the diode) to try to charge the
capacitor up again.
Attach this to a Schmitt trigger gate input and problem solved.
SA Dev
Hi Mike,
Node S.
Thanks--I appreciate the info!!!
SA Dev
Robert C Monsen
SA Dev said:
this?
SA Dev
VCC Schmitt Trigger
+ T (eg, 74HC14)
-------o o----+-----+-----------| >O-
R | | --- C
GND
Make RC >> bounce time (usually around 1ms)
created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
If you are paranoid about your switches getting welded shut, you can add a
resistor between Vcc and the button. I wouldn't bother. Good values are
0.1uF, and 10k.
Regards,
Bob Monsen
Spehro Pefhany
VCC Schmitt Trigger
+ T (eg, 74HC14)
R | | --- C
GND
0.1uF, and 10k.
I think I'd put the resistor in. That circuit tries to do nasty things
to the power supply.
Best regards,
Spehro Pefhany
