Renfred
- Jan 1, 1970
- 0
Hi out dudes and dudesses. I have a seven year old that has for most
of its life had problems pumping out waste when in the draining cycle.
It often requires multiple starts before it will complete a whole
cycle, the pump is running but very little comes out, then it appears
to clear itself if you stop and start it a few times. I have stripped
the machine and checked the pump and outlet pipe etc. and the only
susplect item is a non return valve in the drain, but this appears to
be OK. Anyone struck this problem and found a cure? Any feedback
greatly appreciated. Cheers, Renfred. (Note : remove "x" from xrenfred
in email adddress)
Remove (X) from xrenfred for correct email address...thanks.
in email adddress)
