Simulating an RL circuit
John Larkin
John, Are you just discovering that trick?
In general: R*C = L/R
I was using that to make inductive drivers for modems ~1977.
But it dates MANY years back to GenRad bridge designs.
...Jim Thompson
I think I'd seen it a long time ago, and forgot. I started thinking
about the step-response currents in each leg and slapped meself upside
the head. Duh.
We just rediscovered it in the context of split-path amplifiers. As a
practical matter, to make it really precise, one would probably have
to use a little Coilcraft slug-tuned inductor as part of L, to tweak
things up. There will be capacitive parasitics in L, too, a more
serious issue if this is to be truly wideband, like DC to 1 GHz for
starters.
John
Jim Thompson
the head. Duh.
starters.
John
Yep. Although the GenRad bridges used precision wire-wound resistors
paralleled with carbon resistor plus a cap.
I think it's actually fairly good even at frequency extremes and
slight mismatches.
...Jim Thompson
Phil Hobbs
John said:
You said it. Put me right off my feed, it did.
Hey, if
R = 50
C = 1 uF
L = 2.5 mH
---------+---------R-----------C--------+---------
+---------R-----------L--------+
then this looks like a 50 ohm resistor at all frequencies.
That has some serious possibilities.
John
That's a two-pole RC diplexer, viewed from the source's perspective.
Those are commonly used in receivers to ensure that the mixer sees a
constant 50-ohm load, which is very important in maintaining mixer
linearity.
Cheers,
Phil Hobbs
John Larkin
linearity.
Cheers,
Phil Hobbs
So now we can put an amplifier in each leg. It gets trickier if the AC
path doesn't have a simple single-pole rolloff, but we can probably
work around that.
John
