V
Vivek N
- Jan 1, 1970
- 0
I tried building a single transistor LED flasher like this :
http://cappels.org/dproj/simplest_LED_flasher/Simplest_LED_Flasher_Circuit.html
I didn't have the recommended 2n2222 - I tried with a BC548, 2n2369 and 2n3055 - None of them work.
I'm using a trimpot set to 2 kiloohms and a 470 microfarad capacitor. Instead of a 100 ohm resistor I put 3 superbright LEDs in series.
I get 1.2 volts across the LED and 8.6 volts across the capacitor. My supply is exactly 12.8 volts
Does this required negative resistance effect only work with specific transistors?
