Skin Effect in Solid/Stranded/Litzendraht Wire -Guy Macon
Ecnerwal
Guy Macon said:
I am curious about the four cables. Three phase is usually
configured as delta (no neutral), not wye at those voltage
and power levels. HVDC tends to use two condutors, and even
the fairly rare six phase and twelve phase systems don't use
four conductors. Any idea what was going on there?
Perhaps each of the 3 sets included one spare conductor? Between "cost
of digging trench" and "Cost of being down" a high degree of redundancy
might well make sense .vs. saving money on cables at installation time.
Robert Baer
Tom said:
Thanks, JK^2! That leads to some explanations about the methods used
to keep galvanic action from wiping out the steel core in short
order. I know from experience that a small nick in a copper-clad
steel conductor will cause the steel to corrode quickly (and generally
the wire breaks then). Interestingly, a search on "CCSR" yielded
nothing interesting, and on "copper conductor steel reinforced" seems
to just yield pointers back to copper conductors or steel reinforced
aluminum conductors. Thanks again for the search term that let me
actually learn something. (Now we'll see what the local power company
replies to my question about the conductors they use for both long-
distance and local distribution...)
Cheers,
Tom
Recently, an article in EE Times (Oct 8, p.39) about protecting
electrical devices has some nice data on skin depth.
They explain it is due to "..a back EMF is created in the center of
the conductor, which opposes the current flow".
Hmmm...i thought that the current flow created a magnetic field (in
this case cylindrical, centered at wire center) and the "inner" field
opposed the "outer field", thereby "pushing" the current away from the
center.
So..one could correctly say that there is a "skin effect" even at DC.
One could observe this at reasonable currents (say 100 amps) using
multiple wires (thin insulation if one wishes) twisted around a central
wire.
JosephKK
Tom Bruhns [email protected] posted to sci.electronics.design:
Hi Win,
Ah, back when copper was cheap... ;-)
Of course, that's an entirely different application than the one I
was thinking of, where the wire is strung between towers and
generally is
not insulated -- and where strength matters. Tim W. says that yes,
cores are commonly steel. I tried a web search just now but didn't
turn up anything useful. Maybe I'll drop a note to our local PUD or
the like and see what they say. I suppose with the current price of
copper, Pirelli would consider making the core from some relatively
inexpensive and much lighter material. I wonder if the construction
of long distance transmission lines was covered in that old power
engineering book you got from me about three years ago. Might be
interesting to compare "then" and "now."
Cheers,
Tom
Try "ACSR" (aluminum conductor, steel reinforced). There is a whole
series of standard sizes named after birds.
Tom Bruhns
Cheers,
Tom
JosephKK
used to keep galvanic action from wiping out the steel core in short
generally
seems to just yield pointers back to copper conductors or steel
reinforced
company replies to my question about the conductors they use for
both long- distance and local distribution...)
Cheers,
Tom
You are welcome.
Rich Grise
center.
Yes - that's two different ways of saying the exact same thing.
Probably not - a DC magnetic field doesn't generate any back EMF.
wire.
OK, go ahead and do the measurements, and post your results.
Thanks!
Rich
Spurious Response
Bullshit. It does upon energization, and upon removal of power. That
is, in fact, EXACTLY how a car coil works.
Tim Williams
LOL. So the only back EMF from a "DC" field is when it's no longer DC, eh?
Point in case.
As punishment, do ten Fourier transform integrals.
Tim
JosephKK
Spurious Response [email protected] posted to
That
Wrong again. It is a simple flyback converter.
Guy Macon
Tim said:
Spurious Response wrote...
Point in case.
Unless the voltage has existed since before the beginning of time,
it isn't really DC -- just a reeeaaallly low frequency AC. <grin>
that's what makes doing those ten Fourier transform integrals so
tough; the infinity that pops up when you try to calculate zero
frequency <bigger grin>.
Robert Baer
ChairmanOfTheBored said:
In current solid state designs, yes. Capacitive discharge even (a DC
pulse).
In the days of points, absolutely not.
The Kettering spark system is a classic Flyback circuit.
Robert Baer
**** you, you fucking idiot. Hey, asswipe... over here, we CAPITALIZE
the word I, you uneducable fucktard!
I do not have to compare anything, and I do understand. I built HV
power supplies for the last ten years, asswipe.
A TV deflection circuit is NOT a flyback supply, idiot. The flyback in
a TV is in the ANODE supply, you stupid ****.
So??
It *is a flyback system, and labelled as such in a lot of Sam's
FotoFax (to be punny).
ChairmanOfTheBored
Point in case.
Tim
No, idiot! It IS DC! It is a standing field the entire time the
points are closed. The moment they open, the field collapses, and that
is where your precious back EMF resides.
ChairmanOfTheBored
pulse).
ChairmanOfTheBored
That's what certain maths are all about. NEAR infinity, and NEAR zero
work causes some strange and important figures to arise.
One is:
Betty Boop :-]
Put that in your pipe and smoke it.
JosephKK
ChairmanOfTheBored [email protected] posted to
DC
pulse).
If you were educable i could bother, but that is not the case. If you
compared the various waveforms of TV deflection circuits and compared
then to automotive ignition you could understand. But you won't so
you don't. Not my problem, yours and only yours.
ChairmanOfTheBored
If you
But you won't so
you don't.
You're a goddamned idiot. Nice assumption there, you fucking retard.
That's like me saying "since you assume, you MUST be retarded." Guess
what, dipshit? My remark is far closer to being correct than your is or
ever could be.
IF you even knew what a collapsing magnetic field does, you MIGHT
understand. The problem is 100% yours, idiot.
W
Winfield
They were very likely DC links.
No, it was 60Hz ac, 115kV. I know because they asked
us if we'd be affected by the radiated magnetic field,
being only 100-feet away from our labs, and they and we
undertook an analysis, which showed we were OK about it.
(I had suggested they twist the "wires" but that didn't
go over well, they didn't want to twist four conduits.)
ChairmanOfTheBored
If they were in heavy lead jackets, it is very likely that there would
have been no radiated EMI even a few feet away.
More like twisted brains.
