Skybuck's Universal Code 5 (The Native Version)
MooseFET
What you mean storing it as a group ?
Storing it sequentially or storing it as a group is the same thing to me at
least.
So explain yourself if you believe you were not mistaken.
Sequentially means one after the other on the media. Disks are rarely
used this way. Things are usually written in sectors. The sectors
may not be in order. Normally you don't see this when you read and
write because the OS hides this from you.
If you simply allow the OS to work with the data as a single flat
structure you may have one entry that is partly on one sector and
partly on another. This means that to seek to that element and read
it, two sectors must be read. You will take a major speed hit if you
allow that to happen.
MooseFET
recent invention hahahahaha =D
1. It does look like a linked list. However linked lists are usually used
to store individual elements.
In this case the entire linked list is a single element or integer. It's
one big integer.
A scalable integer for that matter.
2. I believe the linked list is a better structure than an array.
Do you know about pointer chasing?
It is likely he doesn't. He is very new to the field.
MooseFET
One last note:
To truely make it a universal code the pointers could be relative to itself.
So the location of the pointer itself functions as base zero.
This way the maximum gap between elements is 2^32 bytes or something like
that.
Which means unlimited ammounts of memory can be used as long as the gaps
between the sub integers is never exceeded.
This ideas requires extra processing though:
Take the address of the pointer and add the contents of the pointer to the
address to get the final address of the next element.
Not to bad... just a few instructions extra.
Why let it be an instruction? The add process could have its own ALU
section in the CPU. If the pointer is loaded first, there is time
while the data section load is happening for hardware to perform the
add.
If you have a machine with a 128 bit bus, you would be far better off
going to a pair of 64 or 32 and 96 bit values. If you want speed, you
want to use the whole bus.
There are a few operations that can be done more quickly if you can
get to the MSB of the value. You may want to make your linked list a
doubly linked list and keep a pointer to both ends.
SoothSayer
I assume when I tell the OS to write a file sequentially it will do it's
best to do so.
That is not one of the commands at your disposal to even "tell" the OS
to execute.
Wrong layer, dipshit.
Skybuck Flying
best to do so.
If you believe this is not the case then you will have to proof that ;)
Most sectors are 512 bytes, so 64 pairs of integer and pointer will fit in
it.
Worst case scenerio would be a little offset, so than 62 pairs would fit in
it.
Also harddisks are pretty smart.
The chance is big they will read the next sector and cache the previous
sector anyway.
So no additional seeks are needed if the data happens to spill over onto the
previous or next sector.
Worst case scenerio sectors are somewhere else, which means 1 full read for
the 62 pairs. 1 read for the previous spilling
1 read for the next spilling.
However since the fill was written sequantially, the next integers and
previous ones will be cached/read/write as well.
So these can all be considered full reads.
Which means the spilling onto different sectors doesn't really have to be a
problem.
Which means the file fragmentation is the only real problem.
Bye,
Skybuck.
SoothSayer
it.
Nope. If it is formatted with a file system recognized by the OS or
APP, then there will be overhead on any data segment YOU wish to write to
it. There has to be a "file" written, regardless of how you think you
want to structure your data set.
MooseFET
best to do so.
It doesn't.
I know this not to be the case and yes I do have proof. I have the
source code for the part of the OS that does this function. I have
also used to tools to examine what is really on the disk.
it.
Elsewhere in the thread, you will find my comments as to why it may
not be 64 bits per entry if you want it to go fast.
sector anyway.
You don't understand what really goes on with cached disk operations.
It still drives up the processing time.
Think about the FAT based system to see why it still takes some time
even if no seek is needed.
David L. Jones
Now that a new day has broken it's time to clearify some things about my
1. It does look like a linked list. However linked lists are usually used to
In this case the entire linked list is a single element or integer. It's one
big integer.
Rubbish, it's just a linked list. Anything else is an illusion created
in your silly alternate reality.
Dave.
Robert Baer
add.
Gee, that reminds me of the FORTRAN Increment and Decrement fields as
well as the contractions for their names used in LISP..
TheKraken
How does the operating system find free sectors to write data too ?
Not that it matters much.
You have no clue what does or does not matter.
I have no access to the underlieing file system.
And writing one own's file system is a bit over the top don't you think ? :)
For you, yes. Considering that you do not even know what is going on
with an existing file system, I hardly think you could deal with
authoring a new one.
MooseFET
On FAT systems, it searches the FAT table looking for a magic number
that indicates a free sector. Many other systems make the free
sectors into a big linked list.
It makes sense to know a little about what the OS does so that you can
get the most speed out of it.
MooseFET
It was hardly a new idea I was suggesting, just the application of an
old one to this problem.
Starting with the top bit really speeds up the computation of an
unnatural-log.
Skybuck Flying
Well I sure didn't learm much from you, welcome to the ban list.
Bye,
Skybuck.
Skybuck Flying
Nonsense.
Load whatever you need into RAM and proceed from there.
That's what RAM is for.
I have 2 and even 4 GB of RAM.
I have yet to encounter a situation where the harddisk is a real bottleneck.
Bye,
Skybuck.
Robert Baer
Bye,
Skybuck.
Simple, it writes to the first clustor that is NOT marked as used.
MooseFET
Since you clipped the very thing you are so unwisely calling nonsense,
I'll put it back
**** begin insert ***
**** end inserted ****
Nonsense.
You seem to have an extremely poor understanding of the subject if you
call my posting that.
To load it into RAM you need to read the disk. You wanted speed. Now
you are throwing away speed hand over fist just because you didn't
understand the subject. Go read up on it a bit and you will see.
I have 4GB and it isn't even close to enough. Just the raw data file
for one of the things I am doing is over 2GB. Forunately, I can
operate on it in sections. By carefully arranging how it is broken
up, I have got the processing time to be less than 8 hours.
The nice folks at Linear. Put a 48 Bit "do it yourself" virtual
memory system into LTspice. This is because the data they have is
well over 4GB.
You haven't done much then.
MooseFET
That is not how Windows really does it. For FAT devices, it has a
needlessly complex way of selecting which sector to use. The first
fit method tends not to lead to fragmentation. The Windows method is
carefully tuned to lead to a great deal of fragmentation. This is why
you have to defrag so often on a windows box.
V
Vladimir Vassilevsky
There are two different things: the data structures which describe how
the disk space is used and the algorithms which operate with those
structures. The smart and the dumb algorithms are equally applicable to
FAT as well as any other structure.
Not too big of deal. We developed POSIX compatible FAT filesystem to be
used with our OS or as a standalone. The allocation algorithm is more or
less smart; there is a severe speed penalty for the fragmentation with
the flash cards!
I plonked him a while ago. His posts are mostly nonsense, not worth reading.
What is it, if this is not a secret? RF design?
well over 4GB.
I know a guy who does the Spice level simulation of the microprocessors;
he is complaining about that sort of problems :)
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
Skybuck Flying
Simply read file data sequentially from 0 to N-1.
This is garantueed to provide the fastest performance.
If it doesn't then it's a file system problem.
I would recommend to defrag the file system.
It's up to the file system to make sure the fragments of the files are as
good as possibly de-fragmented.
Then it's up to me to make sure I read the files fast with a good algorithm.
For little files this is easy for big files over 4 GB special handling will
be necessary.
So I am not really seeing the problem.
If I store many, many, many, many integer lists as described, then what is
the problem ?
Simply read the lists sequentially from files should work just fine.
Bye,
Skybuck.
