Slayer exciter questions and problem
isaac hughes
Apr 19, 2015
5
wireless-diagram slayer exciter.jpg DSCF0917.JPG DSCF0920.JPG DSCF0921.JPG DSCF0924.JPG So I recently built a slayer exciter from an online schematic that uses the 2n2222 transistor, I wired everything up and it worked fine. I then decided to modify it a little bit and add a 2SC5242 NPN Epitaxial Silicon Transistor and swapped out the led for a diode that can handle a bit more power. this time though i hooked up four nine volt batteries in series giving me just under 36 volts, it worked just fine and even lit a florescent bulb brighter (and froze an electronic device I had nearby XD ) but when i was looking at the voltage it was dropping at a pretty fast pace until it couldn't power the secondary anymore. so the few questions i have is is there anything I could optimize or swap out to make it more efficient and last longer and would it be possible for me to connect a 12v 1A unregulated wall wart to it or should it be a regulated power supply, I will be mounting the circuit at a later time on perf board and make a proper primary winding.
Primary: 5 turns
Secondary: around 700-800
has a top load on the secondary
EDIT: the schematic is the original but the 2n2222 transistor and the led were swapped with the components listed above
14,485
how about showing us a schematic of what this is supposed to be
I have never heard of a "slayer exciter"
duke37
Jan 9, 2011
5,364
I do not know how this works without current in the secondary.
An led is different to a diode, it works similar to a Zener, with a voltage drop of under a volt in one direction and 2 or 3 V in the other direction so limiting the base/ emitter voltage. Exceeding this voltage will degrade the transistor and make it fail.
isaac hughes
Apr 19, 2015
5
i did not realize an led was similar to a Zener diode, that is interesting. and the problem i did have with exceeding the voltage was when i used the 2n2222 transistor it would get to hot to touch ( even tried to mess with the resistor values but would still get hot so i decided to use a beefier transistor and use a regular diode at higher voltages.
Sai Kishore
Aug 11, 2018
In circuit diagram
And connection diagram
LED is connected different which is correct
How you made secondary coil with turns and pipe dimensions
HellasTechn
Apr 14, 2013
1,579
We should not forget about physics. We can NEVER get more energy than what we give !
