sleep mode for PIC
Rajinder
Jan 30, 2016
568
Hi
I am using a PIC 18F4550 and want to put it into sleep mode to conserve battery life then wake it up using a 'wake up from interrupt'
My question is what I need to do with the I/O lines?
A basic sleep function will put the PIC into a mode which it consumes around 40uA.
However, if other things such as I/O lines, WDT etc are configured correctly, the current consumption can be reduced further.
Any help would be appreciated.
kellys_eye
Jun 25, 2010
6,512
The datasheet should specify the various requirements and/or configurations for sleep mode.
What does the manufacturer say?
HellasTechn
Apr 14, 2013
1,579
I was just about to suggest a datasheet also :) such info would only be found in there !
Sadlercomfort
Ash
Feb 9, 2013
424
Is your question how to put the microcontroller into sleep mode? Or specifically how to setup the config bits and I/O lines to reduce power consumption?
Rajinder
Jan 30, 2016
568
It is how to set the configuration bits and I/O bits to reduce the current consumption further.
Rajinder
Jan 30, 2016
568
Thanks all for your replies.
If I make the I/O ports as outputs and drive them low, turn off A/D, UART etc
Would that be enough?
Raj
Depends on what is connected to the ports. For example, if there is an LED beteen V+ and the port, you would set it to high to minimize current,
Rajinder
Jan 30, 2016
568
The program flashes an led on for 1 sec then off for 1 second. The port line driving the led is then made high. Note the led is driven by a pull up to 3v, cathode to pic I,/o line.
The other ports have nothing connected, so I made them all o,/p and driven them low.
The pic uses the internal oscillator.
However using the following inline assembler code after the led is off:
asm sleep;
Results in 4-5mA still being drawn by the circuit. I think it should be around 5uA.
Any ideas?
