I've been following this thread rather loosely for the past several days,
so please pardon me if I repeat previously addressed thoughts.
Arfa, I understand that you've stated that you're using lamps labeled as
60-watt in your fixture. Have you actually measured the power consumed
(for instance, using a Kill-a-Watt or similar meter) by the lamps? It's a
possibility that the lamps have been mislabeled, and you actually have 75-
or 90-watt lamps instead of 60-watt lamps.
Since an operating incandescent lamp is essentially a resistive element,
the power consumed should be RMS power, which is the heating value of the
power. Sixty watts RMS into a resistive element should produce the same
amount of heat, whether it's in a large glass bulb or a small glass bulb.
The temperature of the bulb might be higher in a small lamp because it has
a smaller radiating surface. Power that is concentrated in a small area
will have a higher temperature than the same power that has been spread
over a larger area.
Is the radiating surface area of the new lamps small enough to cause the
increase in temperature that you're experiencing?? I suppose the math
could be done to derive the rise in temperature of your new lamps... would
be interesting to see the results.
My ending thought on the issue is that, IMHO, the telling story would be
in the reading of a power meter in the circuit. If you don't have a power
meter such a the Kill-a-Watt, then you could measure it directly with a
voltmeter and ammeter. V * I = P no need to measure phase since it's
essentially a resistor.
Hi Dave
I haven't measured the actual power consumption of the new bulbs. A few
years ago, I would have been surprised if the figure quoted on a lamp was
not at least within say 5% accuracy, but these days, with the reduction in
integrity of just about everything, and the fact that much manufacturing is
now done in 'emerging' industrial countries, I would be less sure of that.
As to whether the new bulb's envelope is small enough to reduce the
dissipation of the heat by the amount noted, I'm not really a good enough
theoretical physicist to make a call of any real value, but given that this
appears to be the only mechanism by which this could be happening, I would
have to say that is probably the answer.
I don't dispute what has been said about 60 watts being 60 watts, or that
heat and temperature are not the same thing. However, radiation efficiency
is key to the relationship between the two, as we both know. A 60 watt amp
with a small silver heatsink on its output transistors will not get rid of
the unwanted heat anything like as well as if that heatsink is black, and
force air cooled.
For all I know, my bench lamp may be a 'special case', and the fitting of
the smaller bulb might just screw up the dynamics of the air circulation
within the shade. As anyone who knows the Terry's Anglepoise will agree, the
shade is not particularly well ventilated. Perhaps it would benefit from
having a ring of 5mm holes drilled around its top ... ??
Arfa
