slow moving DC motor
CALAHAN
Sep 13, 2006
71
I'm trying to find a micro DC motor that will run at 1 rpm. Basically I need a battery powered analog 60 second stop watch that I can hack open - which I cannot find anywhere. Even a battery powered wrist watch with a sweeping second hand would do, but not one that jumps like the quartz movments do. I realize that motors this slow would require reduction gearing and that is fine, as long as the gearing is either on top of the shaft or integrated within the assembley which cannot be more then 1 inch in height. Does anyone have a connections for a product like this?
This is for a toy project I am working on.
Bruce
jgeidl
Feb 24, 2006
35
Can you use a servo?  You could use a continuous rotation servo motor with a BASIC Stamp (or other processor) and PWM (pulse width modulation) to make it maove at almost any rate you want...especialy slow.
Jim
CALAHAN
Sep 13, 2006
71
Sure I could use a servo, as long as it is small. But this basic stamp processor is the issue. Can I buy one that is already made up to do what I want? I bet this would require creating some kind of circuit board, inserting a chip and programming it. This would probably be cost prohibitive, beyond my capabilities, and take up too much room in the toy. Am I right?
Bruce
jgeidl
Feb 24, 2006
35
Callahan,
I don't know of a chip already programmed and you are pretty close as to what you will need to make this approach work.  Perhaps someone has a suggestion that is simpler.
Jim
ante1
Jan 24, 2004
4,136
A small RC servo can be run from a simple 555 circuit.
