Slowing Down the CPU Speed
Brad
I have two WinBook XL2 laptops with Windows 98se. Most of the time, I use
them off line (off the Web) and I don't need the CPU running at full speed
(400Mhz). The problem is the noisy fan that cools the CPU. This fan is not
defective since it is noisy on both laptops and it runs constantly after a
warm up period.
I could not find anything in "Setup" or the manual that allows you to
reduce the CPU speed.
Is there a utility that would allow me to slow down the CPU, thus
reducing the heat up so the fan doesn't constantly run?
Thanks in advance, Brad
Before you type your password, credit card number, etc.,
be sure there is no active keystroke logger (spyware) in your PC.
bob urz
Brad said:
warm up period.
You already have the ultimate CPU slowdown, a 400MHZ CPU.
Newer intel CPU's have speedstep that will automatically throttle down.
Yours is probably too to have it. Laptops run hot. get a cooler plate
for the bottom if you have to.
bob
Andy Cuffe
warm up period.
There MAY be some jumpers inside for bus speed, or multiplier, but
most laptops are fully automatic. If it has an Intel CPU, forget it,
unless you can modify the motherboard.
Cleaning the heat sink and fan might help things.
Andy Cuffe
[email protected]
