Slowing down a fan
Grenge
Hi
I have posted previously about a modified PC case that my nephew is
currently building. It incorporates a 12V car radiator fan into the base.
We have got it running off an old PC power supply, but as was previously
mentioned, it is quite loud and a bit too powerful.
Now we need to be able to slow it down a bit. The specs on the fan say it
runs on 12V and max current is around 11A (11.2A I think?)
How is the best way to do this? I thought about a resistor, but would it
have to be a huge one to take the 11A current? What size resisters would I
need? What would be the best way to do this? I tried doing the 7v trick by
running it between the 12v & 5v lines but the power supply just shuts
down.The fan itself won't be running all the time. It will just be switched
on when extra cooling is required.
Any help would be much appreciated.
Grenge
rowan194
down.
Have you tried running it from 5V only, or is that not sufficient?
Rheilly Phoull
Grenge said:
Hi
base.
previously mentioned, it is quite loud and a bit too powerful.
say it runs on 12V and max current is around 11A (11.2A I think?)
it have to be a huge one to take the 11A current? What size resisters
would I need? What would be the best way to do this? I tried doing
the 7v trick by running it between the 12v & 5v lines but the power
supply just shuts down.The fan itself won't be running all the time.
It will just be switched on when extra cooling is required.
Grenge
If you are determined to continue with this overkill, find out what current
the fan draws at say 9v and provide a suitable supply. There are many other
fans available that will move the air for much less current and less noise.
Grenge said:
Hi
Grenge
There's a DC motor speed controller kit that was done by Silicon Chip
magazine that will do the job for you. I think DSE and Jaycar sell it,
so all you need to do is build it and put it between your fan and the
12v power supply.
two bob
in914 x2 +12
+-------->|--+----------------------+ 1n4001 |
+--[10K]-|<--+ +--------+---------|---+---+-|<--+------.
| | . VCC(8) . | | === 220uF |
| +--RES(4) OUT(3)---+ === | 100nF | |
| . 555 . | | | FAN |
+---------+----TH(6) DIS(7)- | +---+ | |
+----TR(2) CV(5)-- | | |
10nF=== . GND(1) . | | ||<-.^ IRF540N
What sort of fly trail is that???
atec77
two said:
in914 x2 +12
| . 555 . | | | FAN |
A shcematic one
atec77
Brian said:
two said:
in914 x2 +12
| . 555 . | | | FAN |
A shcematic one
****Looks like a fly flew through your flue,it certainly is NOT a SCHEMATIC.
Brian Goldsmith.
near enough to be readable as one though ... in the trade I am in a
mudmap...
Brian Goldsmith.
two said:
in914 x2 +12
| . 555 . | | | FAN |
A shcematic one
Brian Goldsmith.
Brian Goldsmith.
atec77 said:
A shcematic one
SCHEMATIC.
Brian Goldsmith.
mudmap...
**** And obviously thick enough not to see the reference to your
"shcematic".
atec77
mudmap...
"shcematic".
Or not caring
as a personal foible I often refer to mud maps as such
now just to remind you when all else fails a spelling comment proves
you as an ass and certainly won't win any discussion.. on the net at least.
two bob
in914 x2 +12
| . 555 . | | | FAN |
A shcematic one
Somewhere back in history in tech, that schematic would be a "FAIL" mark. I
had a boss who used to "create" things like that, and wondered why no one
could get their job done.
Pablo Piccaso, watch out!
rowan194
Brian said:
two said:
in914 x2 +12
| . 555 . | | | FAN |
A shcematic one
For the people too stupid to spend 10 seconds cutting and pastings into
a text editor with a fixed font size I've done the hard work for you:
http://satin.sensation.net.au/rowan/fanschematic.gif
atec77
rowan194 said:
Brian said:
two said:
in914 x2 +12
| . 555 . | | | FAN |
A shcematic one
I have no problems reading it :)
Richard Freeman
Grenge said:
Hi
Get a smaller Fan....
need?
It would not be drawing 11Amp by the time you had a resistor in series....
11A at 12V gives 1.1 Ohm - so a 2 Ohm resistor in series would dissipate
around :
12/3.2 = 3.75A
3.75^2 x 2 = 30W - you would get away with 2 x 1 Ohm 10 Watt resistors in
series and place them in the airflow from the Fan which should keep them
cool enough (You may even get away with a single 10Watt 2.2 Ohm resistor if
it is fan cooled).
Go down to your nearest Jaycar and buy a number of different value 10 Watt
Resistors and see what speed/Noise you get from the fan with different
Resistors in series - be daring Experiment a little - a 10 Watt Resistor
will actually handle 20-30 Watts for a few Hours - or if fan cooled
indefinately.
Bear in mind though that a Radiator Fan may not be the quietest Fan
available.
Regards
Richard Freeman
